Old 02-08-2016, 11:41 PM   #11
sgtlm17's Avatar
Thanks Joshua.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 02-08-2016, 11:43 PM   #12
sgtlm17's Avatar
Do we have the PD 9160 or 9260 converter?
Old 02-09-2016, 11:22 AM   #13
Tombsy's Avatar
My manual is for the 9200 series, I'm going out to the storage lot today I will try to confirm the model.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on custom trailer.
60 days fishing/camping so far
Tombsy is offline   Reply With Quote
Old 02-11-2016, 09:28 AM   #14
Sagecoachdriver's Avatar
We all have the PD 9260 converter chargers with the charge wizard. If you open your fuse panel, there is a little green light that indicates your charge wizard mode. If you feel around next to the light you will find a very small push button that allows you to manually change the charge modes.
Difference in 9100 series and 9200 is the 9200 has the built in charge wizaqrd and the 9100 is a remote add-on.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 02-20-2016, 09:04 PM   #15
sgtlm17's Avatar
Is there anywhere to plug in the remote charge wizard on the 9260.
Old 02-20-2016, 09:28 PM   #16
Yours is definitely different than mine. Do you see a model number?
Suggest you give Progressive Dynamics a call Monday. They do show a remote pendant that is attached to the accessory port on the unit.
Why do you want a remote? I had the 9100 series with the CW in my Winnebago and had to hide it in a closet behind coats as the flashing lights are non stop!
Old 02-20-2016, 09:31 PM   #17
sgtlm17's Avatar
It's almost impossible to get my finger in the small hole to change charging modes. Figured I would put the remote on for easier access
PD website says wizard will attach to all 9200 units.
Old 02-20-2016, 09:54 PM   #18
I know, I use my pinkie or the eraser end of a pencil.
Old 02-21-2016, 12:03 PM   #19
sgtlm17's Avatar
Ok my unit has the new PD4560 power control center. This has the converter integrated below the panel and the charge wizard is part of the control center. It is is 60 amps 1000 watts.
280, diagram, wiring
