Old 02-11-2019, 06:27 AM   #1
3011DS 2018 Fuse Location
I recently lost my gray tank readings on my LCI panel. Black, Fresh, and Propane are working fine. I found a decal in upper kitchen cabinet next to the main fuse panel decal that says "Tank monitor fuses". This is where I'd like to start my trouble shooting, but I have no idea where this fuse panel is located in the coach.
Any Ideas????
Hailey is offline   Reply With Quote
Old 02-11-2019, 07:46 AM   #2
Citrus County, Fl.
GL1800Rider's Avatar
The fuse panel on the 3011 is located under the foot of the bed. You will need your slide extended to access it.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 02-11-2019, 02:15 PM   #3
Tank monitor fuse panel 3011DS
Thanks for the response, but I'm looking for the TANK MONITOR FUSE panel, not the main fuse panel. The decal that shows it is above the sink, but it does not say where it is located. the decal shows a small panel with just four fuses.
I'm on a three month trip in Florida and have the rig stuffed so its hard to start removing panels and tracing wires with out moving lots of gear. I am hoping someone has see it in their rig. I can't find any reference to in in any of the paperwork or manuals.
Again thanks for the response.
Tom
Old 02-11-2019, 03:55 PM   #4
Bezzola's Avatar
On my 3011ds its at the foot of the bed with all the other fuses
Bezzola is offline   Reply With Quote
Old 02-11-2019, 04:21 PM   #5
I don't know the specific answer to the OP's question but on the 301DS there are fuse locations other than the foot of the bed power distribution unit mentioned in previous posts. When my 3011DS was delivered the awning didn't work and the tech said he replaced a fuse behind the panel below the bedroom right side drawers. There are a few in-line fuses underneath the coach by the entry steps and the battery distribution center on the left side of the bottom entry step has some circuit breakers.
tkljr is offline   Reply With Quote
Old 02-11-2019, 06:02 PM   #6
Steeljag's Avatar
Hailey, I’ve had no issues with mine, so no hands on experience, but I believe it / they are located behind, and below, the bedroom closet drawers closest to bedroom door !
Hope this helps !
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 02-11-2019, 06:13 PM   #7
Citrus County, Fl.
I had not thought of that area but it makes sense since it's right above the tanks.
99 Terry 31G
Old 02-13-2019, 03:56 PM   #8
Thanks for all the input. I think the area behind the bedroom drawers is where I'll start. I insulated that area with reflextix last year and I remember lots of wiring in there.
I'll be back in my Miami campground on Friday and will have a chance to start trouble shooting it then.
Tom
Old 02-14-2019, 10:56 AM   #9
Garrette's Avatar
I would pull the LCI panel and check all connections for tightness. Good thing to do even if you are not having problems.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
cat, fuse, location
