Old 07-21-2019, 09:41 AM   #1
3011ds ari conditioner
On the 2018 , 3011ds, it has many round vents in the ceiling; however no air is coming out of them.
The cool air is coming out of the rectangular, air conditioner ceiling grate.
I’m thinking that the hoses or ducts are not connected to the air conditioning unit.
Does anyone have any ideas?
It’s 98* here, and the dinette area is the only cool area. Fortunately it converts to a bed.
Thank You;
Brian French
Brianfrench65 is offline   Reply With Quote
Old 07-21-2019, 09:55 AM   #2
Tombsy's Avatar
On my 2801 if you slide the big vent closed it forces the air thru the small ducts.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 07-21-2019, 10:01 AM   #3
2012 Solera
My 2012 Solera would act that way if I opened the “dump valve” on the AC unit. The “dump valve” is a flap which directs the cool air either out the bottom of the AC unit or through the ceiling vents.
Of note, having the “dump valve” open gets the most cold air into our RV. Routing through the (only marginally insulated) ceiling ducts both heats the air some before it enters and presents resistance to the air flow, reducing the flow rate. Dump valve open and a small fan to circulate the air from the dump valve results in more net cooling in my experience.
Again, these comments are based on my experience with our 2012 Solera - and may not apply to your unit.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-21-2019, 10:30 AM   #4
Okay-thank you.
We had an Atwood air conditioner, and it failed. The replacement unit does not have any obvious name plate.
When we move the damper, the air stopped coming out.
Back to the service for repair.
Thank You;
Brian French
Old 07-22-2019, 07:55 AM   #5
dcheatwood's Avatar
You can also run your front dash ac a while to help cool the unit down.
2018 Forester 3011 DS
forester
