Old 11-15-2018, 03:26 PM   #1
dcheatwood's Avatar
3011ds fresh tank drain valve
Does anyone with a 3011ds have a picture of their drain valve and low point drain tubes? I think i have some missing.
Did one night dry camp Monday and had no water in the tank tho I ran water hose in it for 10 minutes before leaving home.
Looked underneath and I have no cap on cold water low point drain. Not even a fitting to screw one in to. And looks like tank valve is gone too.
Would like to see picture of what it should look like.
Crazy thing is, I spent several nights hooked up to City water a few months ago and had plenty water and no drips underneath.Click image for larger version
2018 Forester 3011 DS
Old 11-15-2018, 03:39 PM   #2
Tombsy's Avatar
The shut off valve should be in the compartment above it with the water pump and water filter.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 11-15-2018, 04:11 PM   #3
sgtlm17's Avatar
The blue line is the fresh water tank drain and is opened with a valve that will be in the RV's water bay. The red line is the one and only low point drain. It is designed to be used when the water heater is in bypass mode and the hot and cold water lines are connected. It has a cap and no valve.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 11-15-2018, 06:50 PM   #4
dcheatwood's Avatar
Ok. I'll look under the bed where fresh tank is.
Old 11-15-2018, 06:52 PM   #5
dcheatwood's Avatar
Well that explains the missing cap. Thanks. Now I'll have to figure out why fresh tank stopped taking water through outside inlet.
Old 11-15-2018, 07:04 PM   #6
dcheatwood's Avatar
Ok. I've looked under the bed. No valve anywhere. Can someone show me a picture of that on a 2018 3011ds?
Old 11-15-2018, 07:23 PM   #7
dcheatwood's Avatar
Found help in the sunseeker thread. Thanks All.
Winterizing 2019 3010ds
Old 11-15-2018, 08:28 PM   #8
Tombsy's Avatar
Found the secret compartment? Right on
Brian
Old 11-16-2018, 03:22 PM   #9
Even though we have a 3051s we also have the same tubes under the RV. It does drip after I have filled the tank up. Our low point drain valve is in the closet.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
Old 11-17-2018, 11:24 AM   #10
Wolverine 1945's Avatar
Use SEARCH on this Page for trouble adding water to the FW tank !!!
Wolverine 1945 is offline   Reply With Quote
drain, tank, valve
