A week ago we bid farewell to our MBS 2401s--last trip out 15MPG.
And welcome our new 3011DS.
As always, the teething problems;
1) Right rear outside tire, today 45 psi, ouch, filled 45 to 80 PSI on Tuesday, back to 78 PSI in an hour... so we've got a leaker.
2) Both air-shocks, filled to 70 psi Tuesday, 45 psi today (are they connected to the tire?;-)
3) tried to measure the spare tire pressure, no go, since they didn't install a 90' tire extender none of my gauges can get at it...
Going to miss 15MPG, we averaged about 14 MPG over the 17,000 we had it. We travel with growing grand-kids, and between the space and meager CCC, we had to move up. DW said if we wait our MBS will be worth less and the 3011DS will cost the same or more, so bought one close to our specifications off the lot...
Can't say I like the extra 7 feet in length, and extra width on the road, but inside it feels spacious even without the main slide out. In the MBS we had more space than CCC, and with about 650 pounds more CCC in the 3011DS... that seems like a lot, however a full 55 gallons of gas weighs in at 330 pounds. Still that extra covers a lot of little things we just couldn't consider before unless towing a trailer. --other places on the forums probably go into the difference between the advertised CCC and the yellow door sticker--the actual CCC--in both our MH's 300 pounds less than advertised--this time we knew to look a the yellow sticker, so no sticker shock.
Auto-leveling (if it keeps working well) it a likely culprit in the CCC battle, and for DW worth the cost and weight.
So far so good, I cut some left-over brown-treat deck planks 2"x 10" x 14" to put under the pads to distribute the weight on our asphalt driveway--just seems like a good idea.
All MH's have a signature sound, a low rumble arrives about 55 mph and steady through 70 mph (about as fast is we are likely to travel) is not pleasant to my ear--overall, there's less noise at 65 mph than in the MBS. I'm told the 6 speed transmission keeps the RPM's lower, the engine sound less, and gas mileage improvement. Not enough data to show--we estimate we are getting about 10 MPG...
It's been a busy week putting the bedding back, getting the kitchen the way DW likes, and I can live with, modifying the refrigerator light with a 12 volt LED perimeter strip, installed the
Surge Guard 35530 30A Hardwire Rated 120V, 30A - 2450 Joules
beneath the bed this morning--still trying to figure the best place for the remote read-out.
Tire-minder TPMS on order--the miserable MBS came from the factory without metal tire stems, or 90 extenders on the rear-- a real travesty. The 3011 came with 4 metal stems and two rubber! Now what? likely some kind of rim stabilizing gizmo. Oh, picked up two TPMS sensors for $50 at camping world--they will be used for the air-shocks...
Not a fan of the Android central control. As a control engineer I realized there's a time for flat panel data entry and a time for hard-wired switches. Sure it's nice to turn on all lights at a press of a button--why not the option to turn on all INTERIOR lights, or outside passenger lights, etc.
Yes, the reading lights in the various area's are manually operated, yeah! Yet it is nice to watch the awing go out as it is operated from my android phone. Perhaps the same for deploying the slides, but common sense says one should be inside when bringing them in (and outside when pushing them out?) Now you have the option.
Haven't driven it enough to know how it handles--especially given the nature of the air-shocks and low right rear tire--I know threads are out there hitting on camber and other issues--I can hope they are resolved by now..
Came through driving rain on the way home from the dealer--no known water leaks! Both slides out in a good down pour, still no leaks, whopee
Radio said "SiriusXM ready", MBS came with, as I recall--going to have dealer install this when tire and air-shock issue is addressed, my goal, the end of this next week.
No GPS NAV on the radio--a mixed bag here--what is the best external RV GPS--I read so many conflicting reviews, reports. Do tell, what's your experience in a Forester or Sunseeker Chassis?
I'm sure I've missed some things and I'll offer an update.
