Old 06-02-2018, 08:56 AM   #1
Gumpster808's Avatar
3051s Bigfoot
Ok so searching I found some but not for the 3051.
Anyone know or have a picture where the Bigfoot hydraulic reservoir is on the 2014 3051?
Havenít completely crawled around underneath yet and didnít spot it where another post had it on the 3011.
Lynn & Dennis
Nights Camped 2017 - 35 / 2018 - 15
2014 3051S - First RV for us
2018 Hyundai Elantra Sport Toad
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
Old 06-02-2018, 11:23 AM   #2
Citrus County, Fl.
GL1800Rider's Avatar
Should be in the same spot. It's above the frame so it's hard to see
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 06-05-2018, 07:34 AM   #3
michael621's Avatar
I asked the service shop to check mine while getting the oil changed, and he told me that each leveler has a tank and pump on each jack. Said they were all 1/2 full so he let them be.
2015 Forester 3051SF
michael621 is offline   Reply With Quote
Old 06-06-2018, 06:20 PM   #4
After reading this thread I thought Iíd check mine out since the last time we were out it sounded like the one leveled didnít want to stop when leveling. I was thinking maybe hydraulic fluid could be low. Mine is a 2015 3010 with each leveler having its own pump, and I had never opened the box where they are to check.I donít know why I thought the reservoirs would be small, but I got a quart of fluid on the way home from work. Letís just say I went back and got a gallon container. The reservoirs are pretty big and the rear ones were lower than the front, but total it probably took over 2 quarts and I filled them to around 3/4.
carol108 is offline   Reply With Quote
Old 06-06-2018, 06:41 PM   #5
michael621's Avatar
About how low were they? Please don't tell me about 1/2 full!
Old 06-06-2018, 06:51 PM   #6
The fronts about half. The rears were probably 1/3. Iím thinking thatís plenty of fluid to work properly, so Iím hoping the problem I had with the one sounding like it wouldnít turn off when leveling isnít something else. Iíve put them up and down several times since then and no problems.
Old 06-06-2018, 07:42 PM   #7
If it’s a central pump and reservoir it will be about mid coach on the drivers side tucked up along the frame rail.
Per Quadra it should be filled to about 1-1/2” from the top.
2017.5 Forester 3051S
2019 Jeep Trailhawk toad
Steve-W is offline   Reply With Quote
Old 06-07-2018, 05:16 PM   #8
Thanks for the responses. Now to get out to storage and check mine.
I think I have the four reservoirs also.
Need to look up the type of fluid too. Know it is ATF but think it is specific type.
Lynn & Dennis
Old 06-07-2018, 06:19 PM   #9
ATF Dextron III is what you need.
Old 06-07-2018, 07:04 PM   #10
Lynn & Dennis
