Old 06-20-2014, 10:09 AM   #1
Question 3051s Hot water tank use
May be a rookie question, but can someone put it in simple terms, when and when-not can you use the electric function on the hot water tank?( eg: traveling down the road , electric or not?)Thanks
wana65stang is offline   Reply With Quote
Old 06-20-2014, 10:14 AM   #2
If you have a Gen.that puts out 110V! and it is running! Youroo!!
Old 06-20-2014, 10:15 AM   #3
wmtire's Avatar
The electric heating element side of the water heater must be powered by a form of 120 volt power. You would need to get this 120 volt power either from being plugged into shore power, having a generator turned on,.......or if equipped with an inverter (like on a MH) then that way (if connected), but this would probably consume the batteries fairly quick as the electric heating element needs 12 amps when on.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-20-2014, 10:16 AM   #4
TURBS's Avatar
If your generator is running while going down the road then you can use electrical side of wh.
If it's not you cant.
Old 06-20-2014, 10:22 AM   #5
Thanks for the posts, I usually don't run gen while driving, so do I have to turn off rocker switch at heater when leaving CG and unpluging shore power or can I just leave it on ? I know the tank must be full of water when pluged in or will burn out element with electric switched on.
Old 06-20-2014, 10:27 AM   #6
TURBS's Avatar
You don't "have" to shut it off as long as you know or remember it always running if plugged into shore power or gennie is running
Old 06-20-2014, 10:38 AM   #7
wmtire's Avatar
I just caught the part where you stated "traveling down the road". Is there a reason you would need hot water while driving, as you also have to have a water supply at the same time?
I doubt you have it, but Suburban does make a Motoraid water heater:
This actually lets the motor of the vehicle heat the water thru an exchanger.
Water Heaters | Suburban Water Heaters | RV Water Heaters
I have read about them, but have ZERO experience.
Old 06-20-2014, 10:39 AM   #8
TURBS's Avatar
My bosses holiday rambler has one.
There pretty interesting!
Old 06-20-2014, 10:39 AM   #9
tanddc's Avatar
I think it is a good idea to turn it off lest we test the fates and forget and drain the hot water tank,
tanddc is offline   Reply With Quote
Old 06-20-2014, 10:50 AM   #10
I have a friend who has a (OLD M/H) it has the (Engine Water Heater Setup) Boy what a Plumbing (Nightmare)! F/R would be (NUTs) to have this as a Option ever! Youroo!! Although History Does Repeat Itself!
305, hot water, tank, water, water tank
