3051S Pantry Problem
Hi all,
Looking for help and see if anyone else had this problem.
Clean out he motor home for winter, took everything out of the sliding pantry and closed it.
When out yesterday to do a few things and when to open the pantry. The release button is stuck in and would not come out pulling, shaking, and so on.Had never seen this before. So finally got the bezel around it off and took a knife to pry/work out the button and got it open. When it is out the button seems to work. When you slide the pantry in, the last inch or so seems to stick or rub and at the end seems to click in place as the latch engages. When push in the button to open and it sticks in and will not open. Back to the knife to get it open.
I have looked all around except on top (need to take a stool to see it) and a better flashlight. But can not see anywhere it is making contact or rubbing.
Not sure if it needs a new latch or some kind of alignment.
Anybody had this happen or ideas.
