Old 06-13-2013, 01:14 PM   #21
Looks good. There are numerous ways it could be done.
Another change I made was in the area of your last photo. If you reposition the fresh water tank drain valve lower (shown to the right of the pump), tee in a line with valve between the cold water system drain line (shown at the left of the pump) and the fresh water tank drain line, you have a simple change that allows you to pressure fill the fresh water tank via the shore water supply. On mine I was able to place the new valve so it could be accessed from the water filter hatch door.
ATVer is offline   Reply With Quote
Old 06-13-2013, 01:35 PM   #22
Plain Old Member
Thanks for the simpler idea on the fresh water fill ATVer. That was on the list. The way you mentioned is lots easier. I had a plan, but probably put way too much thought into it.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
