Old 10-20-2015, 04:59 PM   #1
3150S towing capacity
Like a responsible RV owner, i weighed my 3150s with a full load of gas and water (worst case scenario). I have about 200 lbs of available GVW after adding passengers and pets. I do not carry a bunch of unnecessary stuff and have been very weight conscious with every item on the coach.
I know next to nothing about towing, but that doesn't seem to leave me with much capacity for a toad.
How much hitch weight should i expect to have if i have a reasonable toad? Does this mean i can never max out my water load and have a toad? What advice do you have about towing with this large Class C?
thanks for your consideration.
2016 Forester 3051SF
MMulcahy is offline   Reply With Quote
Old 10-20-2015, 05:05 PM   #2
Correction 3051S
Doh!
Old 10-20-2015, 05:44 PM   #3
If you tow four down, you only have the weight of the tow bar ( less that 50 lbs). Trailers of any kind will have too much tongue weight. The actual weight of the toad doesn't matter much since you can tow 7500lbs.
caesar101 is offline   Reply With Quote
Old 10-20-2015, 11:52 PM   #4
Creativepart's Avatar
Yes, 4-down doesn't add a lot of tongue weight. Next to none really. So that's not an issue. The goal is for the towbar to be on the same plane as the baseplate connection on the Toad. If you used a dolly or a trailer it would be a different story.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 10-21-2015, 10:43 AM   #5
RETIRED AND LOVING IT
n-e-d's Avatar
So your GVWR on paper is 14500 and fully loaded your 200# under? Then your GCWR is 22000 lbs on paper so your within the range of the hitch rating which is 7500 lbs(GCWR-GVWR). I tow a 4000# Cherokee
Mary and Me
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Diesel Cargo Van HR DRW EXT DIY Daytripper "Red Roamer"
n-e-d is offline   Reply With Quote
Old 10-21-2015, 02:51 PM   #6
MNtraveler's Avatar
Good question though because even if you meet your GCWR you still need to meet your GVWR for the motorhome
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 10-24-2015, 09:34 PM   #7
Looking to start towing our 2012 JGC vs the Focus, so want to hear stories.
SkipnTerri is offline   Reply With Quote
towing, towing capacity
