Old 06-29-2013, 11:05 PM   #1
Hmnbrdlady's Avatar
A/C Fan Operation
I have a 2012 3011DS. Whenever I run the A/C, it never seems to cycle off once the desired temperature is reached. The fan keeps running and running. Is this normal?
Hmnbrdlady is offline   Reply With Quote
Old 06-29-2013, 11:19 PM   #2
Denver, CO
garbonz's Avatar
There is a manual fan setting for both low and high fan and also an auto setting. Check to make sure it is on auto. If it is then you may have a relay sticking.
2017 Fuse 23T
Old 06-30-2013, 08:12 AM   #3
Not normal assuming it is, in fact, set to auto and gets to set temp.
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 07-01-2013, 10:37 AM   #4
Hmnbrdlady's Avatar
On my thermostat I have to keep pushing the button in order to select what I'm going to use like the A/C or heater. So whatever the fan is set to runs concurrently with the A/C then even if it's the A/C that I've selected?
Old 07-01-2013, 10:47 AM   #5
Dave_Monica's Avatar
Nothing wrong with running the AC fan continually...I do that whenever the AC is running to help move the air around and balance the temperature in the camper.
Dave
Old 07-01-2013, 10:49 AM   #6
fonzie's Avatar
If you have Dometic Single zone thermostat, you need to put on auto. Here is manual page 10 and 11.....
File Type: pdf Dometic Thermostat- Single Zone Digital.pdf (1.40 MB, 32 views)
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 07-01-2013, 10:50 AM   #7
TURBS's Avatar
Dave
X2
Old 07-01-2013, 11:08 AM   #8
tanddc's Avatar
Dave
Also helps cut down on the noise from the party campers next door
tanddc is offline   Reply With Quote
Old 07-01-2013, 05:35 PM   #9
Hmnbrdlady's Avatar
Thanks everyone for the ideas & manual! My RV was missing a lot of the owner's manuals when we took delivery and I guess this was one if the missing ones. I wish I would've thought to post this much sooner.
Old 07-03-2013, 06:18 AM   #10
I run mine on low all the time as well. I don't like to hear it stop and start constantly.
DebbieMH is offline   Reply With Quote
