Old 08-08-2016, 12:50 PM   #1
A/c unit problems
I have a 2016 Forester Tracer 300AIR. I'm not sure if the A/C is working right it's a Domentic brand the A/C compressor cuts off when it get to the Temp that the thermostat is sitting on but the fan run constantly is this normal?? We are new at RVING so any help would be greatly appreciated Thanks
happycamper16 is offline   Reply With Quote
Old 08-08-2016, 01:43 PM   #2
2012 Solera
Normal if fan set to "Hi" or "Lo". Set fan at thermostat to auto "Au" and it will turn on and off with compressor. Will also change speeds (with a delay) as it gets close to set point when set to auto. Set thermostat to fan and use + or - keys to choose fan setting.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-08-2016, 06:27 PM   #3
sgtlm17's Avatar
Exactly.
X2
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 08-09-2016, 07:01 AM   #4
Thank you I will check that
