Old 07-15-2019, 11:27 PM   #1
AC model number ???
Have a 2016 3011DS, bought it new.
The other day I was just going back through all the info that I got with the new rig and discovered that I have nothing on the AC. I do know it's a Dometic and 13,500 but no idea what model it is.
Just wondering if anyone has this unit and can possibly tell me the model? Would like to get a user manual/installation manual.
I did send request via Forest River web site but no answer yet (it's only been a day).
Any help and or suggestions greatly appreciated.
Due to depreciation the above opinion is now worth less than what you paid for it.
Everyone is good at something... I happen to be a good bad example.
2016 Forester 3011DSF
Oregon is offline   Reply With Quote
Old 07-16-2019, 12:06 AM   #2
Coach
Brisk air IIs are pretty common on many RVs, as far as model number, there are different numbers for the unit if it's ac only or heat pump. If your able to get under the shroud on the roof you'll find a plate with model and serial numbers. If you're not able to do that, try and take a picture of the unit and post here so we at least have a visual reference.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-16-2019, 05:17 AM   #3
whirledpeaz's Avatar
I know you have looked through your documents but my ac model and serial were on a photocopied piece of paper along with the model and serial of every device in the TT. But I did also have the owner's manual though.
2020 Rockwood UltraLite 2608BS
2017 F250
whirledpeaz is offline   Reply With Quote
Old 07-23-2019, 11:44 AM   #4
I also have a 2016 3011 and had AC issues and was replaced the first summer it was in operation. Turns out that Dometic had a bad batch of these 13.5 units. You can get the AC info right inside of the AC shroud. For reference I've attached a pic with some info for mine which should be the same except for the serial number.
newRVer is offline   Reply With Quote
forester
