Old 08-02-2018, 05:34 PM   #1
AC Shorts out
In my 2016 FR 2401 MBS. Every time I start my AC the generator shorts out. I have to set the Temp to 89 then start AC on Low and it works. Then after running a while I can go back and set AC on Auto and it runs fine. Can anyone give me insight on this matter. And how to correct.
frankc7037 is offline   Reply With Quote
Old 08-02-2018, 05:45 PM   #2
Mr Towed's Avatar
With no information about your generator provided I will assume it is a small one and the startup amperage is too much for it.
for people to be able to help please provide the follwing:
1)What generator do you have?
2)What AC do you have? 13,500 btu?
3)Does the AC work fine on 30Amp shore power?
4)Has the AC functioned fine with this generator in the past and it suddenly started doing this?
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:???
Mr Towed is offline   Reply With Quote
Old 08-02-2018, 07:14 PM   #3
Ac shorts out
Generator is a Cummins Oman QD 3200. 3.2 Kw,3100 rpm,120 v ac, 26.7 amp.
Always had the problem. There is no problem when hooked to shore power.
Old 08-02-2018, 07:42 PM   #4
Ac shorts out
Its a Dometic B57915 Roof AC 13.5 K 13.5 Btu
Old 08-02-2018, 08:02 PM   #5
cavie's Avatar
Install a "hard start capacitor" on the AC. Set WH and fridge to gas when on Generator.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 08-02-2018, 08:04 PM   #6
wild guess and simply a guess. do you have all other devices that use 110 vac turned off? like the water heater, refrigerator.
i could see getting to a site and turning the generator on to run the a/c. but the water in the heater is cold and as soon as 110 vac is available the water starts to heat it using the electric heater. no much load on the generator. but then after a while the water gets hot, the electric heating element turns off, and now generator runs a/c.
again just a guess
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 08-02-2018, 11:24 PM   #7
2012 Solera
Several posts in the past related to the Onan 3200 diesel and A/C. E.g.:
Diesel generator problems
Sounds like the Onan 3200 Watt diesel is “marginal” - can work, but requires close power management.
JLeising
2012 Solera "S"
Calif SF Bay Area
