Old 02-29-2016, 02:19 PM   #11
"My rule of thumb on RV A/C is divide the coach length (ft) by 2. That's the minimum A/C requirement in the South."
That's why I didn't even think of getting the smaller AC unit. We live in NJ now, but are probably moving to NC in the next 12-18 months.
newRVer is offline   Reply With Quote
Old 02-29-2016, 03:05 PM   #12
Originally Posted by gamidon View Post
I have the same Coach which was 6 months old, but it has a 15,000 BTU unit. I was in Destin, Florida in November, December, and the Air wasn't cold and at night the Heat Pump wasn't warm. I went to Dometic's website to find a local dealer. I called them to come to our site, they found the unit was not working correctly. They handled it totally on warranty thru Dometic. I had to pay the initial service call $75.00 but no more because I drove to their shop for the swapping out of units. Also Forest River reimbursed me for the $75.00
When the AC was replaced is the camper staying cool in hot weather ?
Zoe-Woody is offline   Reply With Quote
Old 02-29-2016, 03:09 PM   #13
I believe there was a leak in the compressor and since it was under warranty Domestic just replaced the entire unit.
gamidon is offline   Reply With Quote
Old 02-29-2016, 03:13 PM   #14
After replacement unit cools on Hot days and heat pump warms on cool evenings. Both heating & cooling are handled by the same unit
Old 02-29-2016, 04:37 PM   #15
We hang a blanket to block off the cab area when it's cold or hot outside. The cab has very little insulation. When we get to our campsite in hot weather, I open the hood to let the engine heat out. Otherwise, a lot of heat comes through the doghouse.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 02-29-2016, 04:40 PM   #16
Thanks that is Avery good idea
I am beginning to think there is an issue with the AC unit. However, when I fix the unit I will still open the hood and use a blanket
forester
