Old 06-15-2016, 04:03 PM   #11
Sagecoachdriver's Avatar
Originally Posted by BamaBob View Post
That's what the generator is for
(BTW, you DID do a nice mod!)
The National and State parks we frequent all have generator hours. We seniors often forget to recharge the batteries .
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 06-16-2016, 01:44 AM   #12
Did finish the wiring late this afternoon. Found it a challenge to get the wiring down to the back of the outdoor entertainment center radio where I had power. Wired it up and were done!
Old 06-16-2016, 06:55 PM   #13
MH Noob
Did you have to fish it through the wall?
Slimjc is offline   Reply With Quote
Old 06-16-2016, 07:05 PM   #14
No, I removed the shelf and carefully placed a drilled a hole thru the pine frame and into the plastic housing for the TV. Measured to make sure I wouldn't hit the TV. I then ran the wires thru the hole down the back side of outdoor TV to the big wire /cable opening where it fed directly to the back of the radio/cd/dvd player and the power supply. I had previously pulled off the shelf above the sofa and reinstalled it with dowels instead of staples.
Old 06-16-2016, 07:08 PM   #15
Herk7769's Avatar
After camping with 3 adults and 4 grandkids and all their toys, I put in 8 USB chargers; and it still was not enough.
HAM CALLSIGN - KC3FFW
Old 06-16-2016, 07:17 PM   #16
Oh my, I know the feeling!
Old 06-22-2016, 08:39 PM   #17
Tinkerer and Putterer
I just bought 2 old work boxes, 2 USB combo plugs and swapped out one outlet on the counter and one in the bedroom with the USB combo plugs. No additional wire required.
HappyGuy is offline   Reply With Quote
Old 06-27-2016, 10:46 PM   #18
Very nice job Sage. I need to add a charging port/110 plug on each side of the bed. should not be too hard since there is power under the bed.
campingtom is offline   Reply With Quote
Old 06-28-2016, 12:59 AM   #19
I may have mentioned before, ours came with 2 USB ports on each side of the bed hooked up to 12v system and regular 110v outlets. Since 90% of our trips are dry camping the 110v receptacle with USB wouldn't work for us since that combined receptacle uses 110v to power the USB charging ports.
roo
