Old 06-14-2016, 05:24 PM   #1
Sagecoachdriver's Avatar
Added another USB Port in Living-room
Since the DW and I both have iPads and iPhones, we are always trying to charge something. We often have to utilize one of the two ports on either side of the bed. To facilitate charging while in the living-room, I wanted to add another port. I could have put one under the cabinet over the dinette opposite where the other is. Instead I am trying out placing the port on the wood shelf above the sofa. So far the DW likes it. Because this USB port has a bright light, I decided to add a switch next to it.
It fit right into the cup holder hole and stuck on with double stick tape. So this can easily be removed if necessary.
ID:	111116   Click image for larger version
ID:	111117   Click image for larger version
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 06-14-2016, 05:41 PM   #2
Dbt803's Avatar
Nice!
Debbie
"Midnight Pearl" - 2011 Berkshire 390 BH
Dbt803 is offline   Reply With Quote
Old 06-14-2016, 07:00 PM   #3
DW asked if it's possible to put a USB charging port on the "U" shaped dinette table? She doesn't like the charging cable(s) dangling down in the corner and on to the table where she is using her iPad or Kindle. Would be a bit more challenging since it's on the Above Floor Slide, but there is power there for the overhead cabinet lights and the other USB port. Have to look into that.
Old 06-14-2016, 07:15 PM   #4
They now make replacement electrical outlets with built in USB ports along with the 120 volt receptacle. Be sure it isn't too deep for your box location.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 06-14-2016, 07:44 PM   #5
True, I have some in my house. Would work fine in an RV park with hookups.
But I think most of us want it on the 12 volt side for dry camping.
Old 06-14-2016, 08:05 PM   #6
True, not a dry camping option.
Old 06-14-2016, 08:19 PM   #7
Back to my original one on sofa shelf.
Going to get correct colored wire tomorrow along with an inline fuse and finish it up.
DW says they should all come with this additional USB outlet. Got that Joshua?
Old 06-15-2016, 01:57 PM   #8
I also just added two usb ports yesterday, one on my side of the bed and one on my wifes. The only 12v usb was on the charging station in the lounge. Got one with a light accidentally but returned for one without. I just took a 12v power feed off the lights, it was very easy to do, didnt need an inline fuse as the lights are fused back at the switch board.
sgh77 is offline   Reply With Quote
Old 06-15-2016, 03:40 PM   #9
I just got back from the hardware store with the wire. I am tapping into my inverter line that is already fused from when I installed it.
Our's came with USB charging ports in the night stands on either side of the bed. I would make my iPhone a WiFi hotspot and plug it into the charger by the bed and use my iPad in the living area thru the hotspot.
Old 06-15-2016, 03:47 PM   #10
BamaBob's Avatar
That's what the generator is for
(BTW, you DID do a nice mod!)
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
roo
