Old 09-15-2018, 08:56 AM   #1
Sagecoachdriver's Avatar
Adding compartment vent for extra propane
I want to bring along an extra propane 20lb tank and carry it in my rear compartment. I don't think it's vented enough. Has anyone added a vent to a compartment for this purpose?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-15-2018, 09:03 AM   #2
Most areas for Propane tanks are very open, some having no solid floor! You would have a tough time keeping other things clean or dry in that case! Youroo! !
Old 09-15-2018, 09:07 AM   #3
Very true, so how do you transport an extra tank to the campground?
Old 09-15-2018, 09:17 AM   #4
We have two 30# tanks and have Never used Both while on any extended trip,even while using furnace in the fall,we don't camp in the Winter! Youroo! !
Old 09-15-2018, 11:36 AM   #5
Remember this is a class c and no real place for total outside storage. Iím sure many have the 1lb cans in closed compartments.
Old 09-15-2018, 01:33 PM   #6
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
Might be wrong here, but I thought the only time they should be in a vented compartment, was if they were in use with the valve open, especially when connected to a regulator. An exception may be with a freshly filled unit, subject to outgassing if too hot? I await the wisdom of the masses!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 09-15-2018, 01:35 PM   #7
Tombsy's Avatar
It probably doesnít really help you but I can carry an extra 20# tank in the storage compartment of my boat trailer, itís one of those diamond plate pick up truck boxes and it will just fit upright. Iím not sure if you have a toad that you could rig up something to carry it.
But I carry some of the little green bottles as well in the mh compartment for the bbq and lil buddy heater to stretch my propane for longer stays.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 09-15-2018, 02:31 PM   #8
onetonford's Avatar
I think they should be vented. Also I know if you keep in a compartment they have to have a label with 2" LPG letters on the door.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 09-15-2018, 09:45 PM   #9
Recently new!
Paulie1138's Avatar
Boy was I wrong with my previous post!!!!! I found this.
http://www.apollopropane.com/pdf/Tra...eCylinders.pdf
2001 Ford F-250 7.3
Old 09-16-2018, 01:10 AM   #10
Looks like the safety plug could work while I travel and then remove tank from compartment. Still no way to vent.
Old 09-16-2018, 07:40 AM   #11
i think there is also some regulation that requires that the compartments that the propane cylinder is store in must be able to be manually opened without any locks and keys.
it sounds like you currently have 20 lb tank(s). would a 30 lb tank fit in the existing compartment?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 09-16-2018, 09:50 AM   #12
I have a 5lb, 11lb and 20lb tanks and there is just enough clearance for the last 2 because of their height, a 30lb would not. Of course not all at once.
Could put and secure the tank in the basket of my wife's tricycle which sits in a custom bike rack off the rear hitch receiver. Not sure if there is enough room to squeeze an 11lb or 20lb tank in behind the front wheel, but the 5lb could. Would that be legal if I could? Looks dangerous especially if rear ended.
Old 09-16-2018, 12:59 PM   #13
New idea!
How about using the drivers side rear compartment where the 11 lb tank fits nicely. Cut and install a hatch cover and install eyelets for tie down. Then add a center lock in the cabinet door and move the lock itself over to the middle and install a lever latch like the left side on the right side. Finish off adding a screen to the outside of the hatch cover and apply a PROPANE sticker.
This will allow me to place the tank inside and secure it, unscrew the hatch cover to allow ventilation and keep the cargo door secure while traveling but unlocked per DOT. Plus it's away from the exhaust pipe on the other side of MH.
ID:	186643   Click image for larger version
ID:	186644   Click image for larger version
ID:	186645   Click image for larger version
Old 09-24-2018, 06:33 PM   #14
Whoops, guess Iíve been breaking the rules for a while. We keep an extra 20 lb tank in the RV when weíre traveling and often Transport one in our Jeep too. Never really worried about venting, never had any propane smells in those compartments, though the compartment we keep our hoses does smell. I guess Iíll have to change how I do this too. :/
Jpontheroad is offline   Reply With Quote
Old 09-25-2018, 06:17 PM   #15
I received the hatch and decal from Amazon, now I need to figure out where to cut the hole??? I can mount the hatch on the floor or side. From what I read, it must be at a spot on the floor or if on side touching floor. Also, it requires 1 square inch of vent for each 7lbs of propane. Going to cover with screen to prevent bugs, dirt and bugs. So, side or floor?
ID:	187542   Click image for larger version
ID:	187543   Click image for larger version
Old 09-25-2018, 07:05 PM   #16
PPST Wannabe
kenandterry's Avatar
I would go with the floor location for ventilation. If you ever change your mind, not to carry propane there, it makes a great hatch to flush dirt or whatever with water. It also allows another entryway for other power or water connections to the interior.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-25-2018, 08:52 PM   #17
I'm thinking the same thing. There is a 3/4" plug for draining, but it's too small.
Old 10-01-2018, 01:57 PM   #18
Finished
So I cut a 4 1/2" hole and mounted the hatch with screen over the inside to prevent bugs etc. Placed decal on compartment lid. The propane bottle will be wedged in up close to the open hatch while traveling and removed upon arriving at CG to supplement main tank, BBQ and Little Red Campfire.
ID:	187990   Click image for larger version
ID:	187991   Click image for larger version
forester, propane, vent
