Old 07-18-2016, 08:19 PM   #1
kdwallin's Avatar
Advice on regular maintenance for Forester 2401W slide ...
After taking our rig out a few times now, I hear different squeaks and rubs and groans each time we extend and retract our wall slide. I have to think there is some tender loving care that must come along with having that wonderful giant wall slide. Any advice from fellow 2400W owners or the reps on this forum?
Kelly & Mary Beth
2017 Forester MBS 2401W
Kelly and MB
2017 Forester MBS 2401W Class C motorhome
kdwallin is offline   Reply With Quote
Old 08-10-2016, 07:28 PM   #2
raptor's Avatar
I don't know you already knew this. There is a recall on 2401W slide. I read some where in here about that.
raptor
2016 Forester MBS 2401R
America is great
raptor is offline   Reply With Quote
Old 08-10-2016, 08:00 PM   #3
ilmor's Avatar
Kelly & Mary Beth
Is it the Schwintek design? There are YouTube vids about maintenance and troubleshooting
ilmor is offline   Reply With Quote
Old 08-11-2016, 10:55 AM   #4
Total Loss's Avatar
-Dry lube on the tracks.
-Keep everything clean.
-When full extending or fully retracting hold the button for 3-5 seconds after it stops to give the controller time to align itself.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 08-11-2016, 11:01 AM   #5
Just A Member
EDABEUT's Avatar
You will always hear the rubber seals squeaking down the sides of the walls and flipping as the slide goes in and out. They are all noisy. I always listen for the seals to flip on the way in and out so I know if they are in correct position. Have someone run the slide in and out while you are outside and watch and listen so you can see what you are hearing.
Ed & Brenda
2015 Coachmen Freedom Express
Liberty Edition 297RLDS
2013 Silverado 1500 4x4 6.2L Max Tow
EDABEUT is offline   Reply With Quote
Old 08-14-2016, 05:22 PM   #6
Garrette's Avatar
I always check the outside seals to make sure they did flip outward. If not, I use a simple yardstick and run it up to flip them out. At the bottom corners, make sure the verticals are flipped out and lapped on top of the bottom vertical.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 09-08-2016, 08:35 PM   #7
kdwallin's Avatar
Thanks all. I have lubed my slide gaskets and mechanism according to recommendations here. In doing so, discovered some extra mini-gaskets, surrounding each row, as pictured here ... Are they supposed to be there? If so, is it important that one fell out while I was lubing? 😳Click image for larger version
Name:	ImageUploadedByForest River Forums1473384933.313433.jpg
ID:	119762Click image for larger version
Name:	ImageUploadedByForest River Forums1473384950.504693.jpg
Kelly & Mary Beth
Kelly and MB
Old 09-09-2016, 06:21 PM   #8
raptor's Avatar
It's so hard to say because most of them are different. It looks like an after thought. Ooooh I cut off too much let stuck a piece of rubber here thing??????????????????
raptor
America is great
Old 09-11-2016, 06:45 AM   #9
kdwallin's Avatar
Thanks, Raptor. Looks to me like they intended these little pieces to be there - there is a pair of them consistently located at all 4 rails (except for the one that fell out in m hand).
Kelly & Mary Beth
Kelly and MB
forester, maintenance, slide
