Old 07-15-2015, 08:14 PM   #31
toslow's Avatar
Originally Posted by steverkemp View Post
2 degrees is default on the current shipping thermostat.
how does a person change it? the default value
haven a blast
toslow is offline   Reply With Quote
Old 07-15-2015, 08:37 PM   #32
ACE110's Avatar
I had the same issue with my AC, right after we got it. It turned out to be the wall thermostat. The dealers tech was able to fix it. Not a 100% on this, but I believe he covered a small portion of the thermostat sensor with a "putty" insulator. Problem solved, & has not reoccurred since.
2012 Forest River Wildcat 313RE
2012 GMC Sierra 2500 HD Duramax
Demco Hijacker 18K Autoslide Hitch
BAK Roll-X Tonneau Cover
ACE110 is offline   Reply With Quote
Old 07-15-2015, 08:52 PM   #33
For the current shipping Dometic thermostat, here is a link to the manual and instructions below: http://dometic3frontend.qbank.se/epi...8b972438cd.pdf
To set the temperature differential the system must be Off. Press the “―” button and, while holding it, also press and hold the On/Off Mode button for three seconds. Release the On/Off Mode button. Then release the “―” button. Press the “+” button to toggle between “d1” and “d2”, “d1” for 1 degree F differential and “d2” for 2 de- grees F differential.
steverkemp is offline   Reply With Quote
Old 07-15-2015, 08:55 PM   #34
toslow's Avatar
thank you,,
the only thing is my t-stat is not LCD
haven a blast
Old 07-15-2015, 08:56 PM   #35
Citrus County, Fl.
GL1800Rider's Avatar
I am assuming you have the Dometic 15000 with the heat pump. Like Steverkemp says, thermostat is set for a 2 degree difference from the factory. On Auto it is supposed to switch over from high fan to low when within five degrees of the setting on the thermostat I believe. If it bothers you, just run it on high until you need it quieter like watching TV or bedtime.
I have mine plugged into to shore power in the yard with the a/c set at 85. If I am working inside I usually drop it down between 75 and 78. On auto is will shut down for a few seconds when it nears the setting and fire back up on low until it reaches the temperature setting then shuts down.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 07-15-2015, 08:59 PM   #36
toslow's Avatar
It has the HI, LOW and AUTO but it's not a LCD display it's the slide up and down setting
haven a blast
Old 07-15-2015, 09:04 PM   #37
Rivnut
Rivnut's Avatar
Go Digital, save future headaches.
Rivnut is offline   Reply With Quote
Old 07-15-2015, 09:40 PM   #38
VinceU's Avatar
Even the old mercury bulb switch had a differential setting. It controls cut in and cut out of the HVAC device. Maybe search the internet for your thermostat, it will show the setting. The difference is band or differential setting. 1 or 2 is very close for older thermostats.
