Old 04-19-2015, 09:15 PM   #1
Air assist suspension
Posted question in tech section, but no replies. We have a me Forester 2501. The manual says 100psi in air assist suspension. Is that the max fill or average amount to keep them at? Thanks in advance!
suscamper is offline   Reply With Quote
Old 04-20-2015, 06:53 AM   #2
ourflat's Avatar
According to the manual, 100 PSI is maximum pressure. I set mine (depending on road and load conditions) between 70 and 80 PSI.
Frank
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 04-20-2015, 07:47 AM   #3
Class C Representative
Joshua Cavitt's Avatar
That is the max fill they can be filled between 5-100 PSI. From the factory normal driving is filled to 60-65 PSI after that it is personal preference.
Joshua Cavitt is offline   Reply With Quote
Old 04-20-2015, 09:48 AM   #4
100 psi is most likely more than you need. Ours does best with 65 when fully loaded.
jrwalkerpa1 is offline   Reply With Quote
Old 04-23-2015, 07:51 PM   #5
Tinkerer and Putterer
Over 75 PSI my ride got harsher in my 3011 which is heavier in the back than your rig. That 65 psi recommendation is probably a good starting point.
HappyGuy is offline   Reply With Quote
suspension
