Old 08-31-2016, 08:40 PM   #1
Air Bag question..
Have a Forester 3011DS which has the airbags to help suspension.
I run the airbags at 70-75lbs when motorhome is loaded and we are using it.
I have recently heard that when we finally store it for the winter I should empty the air bags until next spring when I use it again.
Any comments to leaving the airbags filled, empty them, pros or cons ...
Due to depreciation the above opinion is now worth less than what you paid for it.
Everyone is good at something... I happen to be a good bad example.
2016 Forester 3011DSF
Oregon is offline   Reply With Quote
Old 08-31-2016, 08:46 PM   #2
DaGrinch's Avatar
Yes, inquiring minds want to know!
There's so many things I need to do with the MH as compared to the TT.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 08-31-2016, 09:12 PM   #3
grumpy0374's Avatar
Your rig, like my Lexi, probably has the same airbag system, Firestone.
If you read the owners manual/install info, it will tell you not to run the bags without air. Keep a minimum of 5-10 psi. Don't know if this applies to storage. But i've kept around 30 psi in mine over 3 winters with no adverse effects. I would imagine that keeping air in them would prevent them from developing cracks in any creases that would form if flat.
Tire sitting for a long time with air in it lasts alot longer than one without air.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 09-03-2016, 10:51 AM   #4
Citrus County, Fl.
GL1800Rider's Avatar
I think the only time air is to be let out of the bags, according to the manual, is when the chassis is put up on a lift.
I had my bags inflated to 75 at the start of a 3+ week trip so I checked them prior to leaving and they had dropped to about 40# which I think was a pretty big loss for 3 weeks. However, since the jacks were deployed, that may have had a bearing on the pressure. I don't remember reading anything about not haveing the jacks down when chekcing the pressure. Will need to check them again since it has been a bit over a week and the jacks are up to see what I get.
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
