Old 12-11-2016, 06:35 PM   #1
Air bags
Does cold weather affect the pressure in the air bags? Left with 40 lbs pressure in 32 degree weather, traveled about 40 miles. When we got to our destination the airbags had 22 lbs. Left our destination air bags had about 22 lbs in 60 degree weather. Got home air bags had about 40 lbs. Puzzled !!!!!
5hfarms is offline   Reply With Quote
Old 12-17-2016, 09:16 AM   #2
KJcachers's Avatar
Cold air should affect them just like tires. Check and inflate/deflate as needed before each trip.
2015 Forester 3051s
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
https://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 12-17-2016, 07:57 PM   #3
Air Bags
I fiqured weather would affect them, but not so drastic. Thanks for the response
Old 12-17-2016, 08:13 PM   #4
WFD
In cold weather tires will lose air pressure, usually from around the rims due to cold causing material to contract, but once that pressure is lowered it doesn't come back as temps warm up...only way to get it back up is to physically add air. Not sure if the effect on air bags would be the same.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 02-16-2017, 08:18 PM   #5
Kirk S's Avatar
I'm assuming you're talking about the air springs on the rear axle. It doesn't take much to overfill or underinflate them so they must have a small air space inside which would be very temperature reactive. I will be installing TPMS sensors on mine as well as the tires tomorrow so I can get an idea about the pressure fluctuation. I fill them to 30 psi cold (ambient temp) and your post has me curious about how that may change. Thanks.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 02-17-2017, 05:39 AM   #6
Big1's Avatar
If you are talking about firestone air bags mines seem to holding pretty good now.
2018 Dodge Ram 3500 6.7L CTD
2019 Jayco Eagle 321RSTS
Retired Army MSG.
Big1 is offline   Reply With Quote
Old 02-17-2017, 09:12 AM   #7
Since the weather has warmed up the air bags have stayed fairly stable. I was worried that I may have punctured them, but all is good. Thank you.
Old 02-17-2017, 09:26 AM   #8
Steeljag's Avatar
The pressure dropping from 40 to 22, then returning to 40 seems odd ! Pressure gauge misreading ?
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 02-20-2017, 11:41 AM   #9
Cool
I'm sure that could be a possibility or not a proper reading (it was cold that day), but it seems to have returned to normal so all is good !!!
Old 02-20-2017, 07:04 PM   #10
Kirk S's Avatar
Update: Both air bags set at 40 psi. TPMS sensors set at 100 high and 25 low. Took it for a spin to see how everything worked. Sensors on the air bags doesn't seem to be a good idea. The pressure fluctuations were so wild that the alarm went off at every turn. Oh well, I learned something new. Has anyone else tried this?
Kirk
2017 Forester 3051S
Old 02-27-2017, 09:37 PM   #11
Chief tinkerer
Gidyupgo's Avatar
Netgain, I have not tried it, but since they alarm upon rapid loss, I see the problem. I think I saw wireless air gauges on amazon a while back. Heck, they've got wireless everything else...... probably an app. , heh heh
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
air bags
