Old 10-10-2015, 08:36 AM   #11
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
I'll get a photo of mine - set up from the factory - and post it later on.
2015 Forester 2301 - Chevy
Skip & Deb - Bridgewater, NH & Delray Beach, FL
Forester Fred is offline   Reply With Quote
Old 10-10-2015, 11:07 AM   #12
Apologize for the first photo being a bit fuzzy, but this is the access door to the water pump and filter in one of my side compartments.
Open that door to access the water pump, water filter, cold water system drain valve and anti freeze pickup tube. Note the inline valve for the anti freeze pickup tube. (apologize again for the slightly fuzzy photo, but you get the idea) My water filter is still unopened in the compartment, I didn't bother installing it into the filter housing as we don't drink the water at campgrounds or out of our water tank.
Old 10-10-2015, 11:52 AM   #13
The only reason I use that filter is to keep things from plugging up the sink screens on the end of the faucets. I use a Britt filter for drinking water.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 10-11-2015, 07:22 AM   #14
Wolverine 1945's Avatar
Originally Posted by oldtool2 View Post
It does not take up much room, just cut the line and add a valve and a couple feet of hose. I used an old water hose so I can suck water from a 5 gallon jug when "dry" camping and may need an emergency supply of water. If you are only going to use it to winterize then a short piece of any hose will do.
To winterize I stick the hose in an antifreeze jug, turn on the pump and open my faucets till they run pink. I had two shut off valves added to my outside shower. sometimes I just do that to the shower then shut those valves off. This winterizes the shower but I can still use everything else till I decide to do the whole trailer.
You could blow air thru this line if that is what you prefer.
Jim
I will look again,,, not much room to work in that compartment !!!
I know I am little crazy about winterizing,,, I blow every thing out,,, and still add anti freeze !!! To me it is worth 2 or 3 gallons to be sure every thing is protected !!!
Wolverine 1945 is offline   Reply With Quote
Old 10-11-2015, 07:28 AM   #15
Jim
Thanks for the photos,,, maybe some day I will learn how to post photos ??? LOL !!!
That sure looks different that our 1013 Sunseeker !!!
Old 10-11-2015, 07:04 PM   #16
Thanks I think I will stick to blowing it out with air. Just wondering where the connection was. Thanks for all the responses
5hfarms is offline   Reply With Quote
Old 10-12-2015, 10:58 AM   #17
Your welcome. I am a believer in a photo is worth a thousand words. Much easier to show something than try to explain it sometimes.
Jim
George Bernard Shaw
