Old 10-09-2015, 07:32 AM   #1
Anti freeze syphon connection
I have a 2015 Forester and we love it. Do I have the connection to winterize that picks up the antifreeze and where is it located? We live in south Louisiana and very rarely need it, but would like to know where it might be on the rare occasion that I may need it. Thank you in advance.
5hfarms is offline   Reply With Quote
Old 10-09-2015, 07:59 AM   #2
Forester Fred's Avatar
Mine is in the small compartment where the water pump and water filter are located. There should be a T off the water pump with the siphon hose attached. There's a valve on the T to activate the siphon.
2015 Forester 2301 - Chevy
Skip & Deb
Forester Fred is offline   Reply With Quote
Old 10-09-2015, 08:00 AM   #3
Creativepart's Avatar
Winterizing your coach is a bit of a hassle and not something you do to survive a 3-day cold spell. In extreme situations you'd simply need to heat the coach with the onboard propane heater for a few hours every day if something really unusual happened.
I doubt you need to winterize your coach if you live in south Louisiana. You only need to winterize your unit with anti-freeze if you are somewhere the coach will see sustained below freezing temps - 24 hours a day for weeks and months in a row.
We live in San Antonio and do see as many as 5 to 10 days of sub-freezing temps some winters. But in the 30-years I've lived here there has only been one occasion of sub-freezing temps lasting more than 24-hours straight for more than 2-days.
The water in your coach is not out in the open, exposed to the freezing temps. It is routed through the flooring and walls of your MH. This alone provides more than enough shelter from the freezing temps to survive 20 degree weather for a day or two. And, in the south even when there is a 18 degree night... it's nearly always followed by a 35 degree day.
You haven't said how far south you are in LA, or what Forester you have, but I'd suggest you speak with other motorhome owners or dealers in your area and ask them what they recommend.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 10-09-2015, 08:04 AM   #4
mark0224's Avatar
If you have the connection it should be between the water tank and the pump usually just before the pump. Look for a brass tee with a cap on the tee and valve handle. Looks like this one from Amazon Amazon.com: Camco 36543 Pump Converter Winterizing Kit: Automotive
If you don't have one they are easy to install
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-09-2015, 11:48 AM   #5
Thanks for the responses. I probably won't need it, but good to know where it is if I need it. I live in Lafayette, La., not real cold, but once every so often it does get in the mid twenties for a few hours.
Old 10-09-2015, 11:57 AM   #6
Down there, I would just blow out the lines with air when needed.
hilitephoto is offline   Reply With Quote
Old 10-09-2015, 12:51 PM   #7
Blowing out with air is the way to go. Do not have to deal with purging anti freeze out of lines. We go to -20 with no problem. I do put anti freeze in all drains to protect the traps.
Harkerr is offline   Reply With Quote
Old 10-09-2015, 01:29 PM   #8
Could look like this. Hose on left goes to the fw tank, on right to the pump.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 10-10-2015, 07:24 AM   #9
Wolverine 1945's Avatar
I added one of those Winterizing Kits to our old Flagstaff TT,,,
Worked Great,,, sucked straight Anti Freeze right in to the lines !!!
I do not find room in our Sunseeker 2500TS for one !!!
Wolverine 1945 is offline   Reply With Quote
Old 10-10-2015, 08:33 AM   #10
It does not take up much room, just cut the line and add a valve and a couple feet of hose. I used an old water hose so I can suck water from a 5 gallon jug when "dry" camping and may need an emergency supply of water. If you are only going to use it to winterize then a short piece of any hose will do.
To winterize I stick the hose in an antifreeze jug, turn on the pump and open my faucets till they run pink. I had two shut off valves added to my outside shower. sometimes I just do that to the shower then shut those valves off. This winterizes the shower but I can still use everything else till I decide to do the whole trailer.
You could blow air thru this line if that is what you prefer.
Jim
George Bernard Shaw
Old 10-10-2015, 08:36 AM   #11
I'll get a photo of mine - set up from the factory - and post it later on.
Skip & Deb
Old 10-10-2015, 11:07 AM   #12
Apologize for the first photo being a bit fuzzy, but this is the access door to the water pump and filter in one of my side compartments.
Open that door to access the water pump, water filter, cold water system drain valve and anti freeze pickup tube. Note the inline valve for the anti freeze pickup tube. (apologize again for the slightly fuzzy photo, but you get the idea) My water filter is still unopened in the compartment, I didn't bother installing it into the filter housing as we don't drink the water at campgrounds or out of our water tank.
Skip & Deb
Old 10-10-2015, 11:52 AM   #13
The only reason I use that filter is to keep things from plugging up the sink screens on the end of the faucets. I use a Britt filter for drinking water.
Jim
George Bernard Shaw
Old 10-11-2015, 07:22 AM   #14
Jim
I will look again,,, not much room to work in that compartment !!!
I know I am little crazy about winterizing,,, I blow every thing out,,, and still add anti freeze !!! To me it is worth 2 or 3 gallons to be sure every thing is protected !!!
Old 10-11-2015, 07:28 AM   #15
Jim
Thanks for the photos,,, maybe some day I will learn how to post photos ??? LOL !!!
That sure looks different that our 1013 Sunseeker !!!
Old 10-11-2015, 07:04 PM   #16
Thanks I think I will stick to blowing it out with air. Just wondering where the connection was. Thanks for all the responses
Old 10-12-2015, 10:58 AM   #17
Your welcome. I am a believer in a photo is worth a thousand words. Much easier to show something than try to explain it sometimes.
Jim
George Bernard Shaw
