Old 04-20-2016, 01:11 AM   #1
Sagecoachdriver's Avatar
Anyone add Skid Wheels on the Rear?
We've been bottoming out leaving a few driveway and the "V" shaped welded on skid is getting a work-out. Not sure if it can take many more. Have any of you had any luck with either the bolt-on or weld-on skid rollers? I do keep between 70-80 psi in the air bags depending on whether I have the bike and trike on the hitch.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 04-20-2016, 11:57 AM   #2
I actually had the "V"removed rather than adding the wheels on.
Rossriley is offline   Reply With Quote
Old 04-20-2016, 01:56 PM   #3
HopHed's Avatar
I added them as the skid was almost worn through. I got the metal bolt on wheels. Works great but at some point will have to replace again but will be a ways down the line.
Never thought of taking the "V" skid off completely as noted above. May do it when the wheels wear out and see how it works on our driveway.
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
HopHed is offline   Reply With Quote
Old 04-20-2016, 03:22 PM   #4
HopHed-Any chance you can post a photo?
Old 04-20-2016, 03:35 PM   #5
HopHed's Avatar
Each side. The left was tight with the trailer wiring harness.
1978 Ford Rollalong
Old 04-20-2016, 04:55 PM   #6
Did you get them local? How thick are the shims?
Old 04-20-2016, 04:58 PM   #7
HopHed's Avatar
Amazon for about $80.
1978 Ford Rollalong
Old 04-20-2016, 08:06 PM   #8
Saw some on Amazon. Did you get the 2 1/2" or 3" and the U Bolts don't look as long as yours? Did you use something from Lowe's or HD?
Old 04-20-2016, 08:19 PM   #9
Attachment 105554
Attachment 105555
From your Pic it looks like you just Added 2+" to Early "Touchdown"? Is this Not going the Wrong Way for a solution? Youroo!!
Old 04-20-2016, 08:27 PM   #10
Why not mod the V by cutting part of it off and adding a flat and add the wheels to the flat?
wheel
