Old 11-24-2013, 08:04 AM   #1
smulrenin's Avatar
audio
I have a Jenson JRV210 stereo in the cab of my Forester. Is there any way to run the stereo in the coach without having to have the key in the aux position ? Any ideas?
smulrenin is offline   Reply With Quote
Old 11-24-2013, 07:47 PM   #2
Not that I am aware of. I ran a 12 volt feed wire from the TV socket to a toggle selector switch in the dash. In that way I can select the radio feed from either normal (chassis) or coach battery. You could just connect directly to the coach battery but then the display stays on all the time. The 2013 models corrected this issue with the new Magnadyne radio which has an always on feed from the battery.
The other thing I did is purchase a remote so I don't have to keep entering the cab area to adjust or change the radio. Not sure if Jensen still has it on their website but it was very reasonable, $9.95 including shipping.
ATVer is offline   Reply With Quote
