Old 03-19-2015, 08:23 PM   #11
Garrette's Avatar
I got these instructions from my awning users manual. You will need a pull strap. One came with my rv. It is black, about 1" wide. One end has a small round gray plastic piece and the other has a loop. Some where in your rv, you should have a small rod about 3' long with a round bend a 90deg bend. The bend is for the strap. You will need these to control the awning when you put it back up. It is spring loaded.
You will need to loosen the screw shown and with the help of a partner, pull the awning down. This will will put tension on the awning and you guys will need to control it.
When fully extended, place the pull strap in the tube groove. This will give you something to hang on to. Now you can see the manufactures sticker with the model and serial number.
Using the rod, slowly roll the awning into its stowed position. Re install the screw.
Be advised, I was told not to drive the rv because the awning could unspool at speed, thus the safety recall.
I have never had to do this but being familiar with manual awning, this is what I would do..
Name:	ImageUploadedByForest River Forums1426814564.893076.jpg
Garrette is offline   Reply With Quote
Old 03-20-2015, 08:27 PM   #12
Check the switch first for two reasons. First it may be the problem and the motor is fine. Also, more likely IMO because there was a bulletin about it, the switch has been known to fail with the contacts closed causing the motor to burn up.
Also note that the awning circuit is powered directly from the coach batteries and power cannot be removed from the circuit simply by opening the disconnect switch.
ATVer is offline   Reply With Quote
Old 03-29-2015, 04:07 PM   #13
wesslvm's Avatar
There was problem with awning motors that year, replaced mine after it failed. The switch issue was for earlier units.
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 03-29-2015, 04:39 PM   #14
Scootdawg's Avatar
On our 2014 Sunseeker 2900 we would blow an awning fuse every trip. I learn to pack extra's. When I contacted the dealer they told me there was an issue with the 2014's and how the ground was connected for the awning. I scheduled a service call to fix it, but since traded the Sunseeker in for a 5ver. I'm wondering if they ever had a recall? I bought mine at the end of 2013.
2014 F-150 SuperCrew
2015 Rockwood 8289WS Diamond
Scootdawg is offline   Reply With Quote
Old 04-01-2015, 07:23 PM   #15
Garrette's Avatar
Awning motor issue
Yes, there was a recall on the 2013/2014 9100 power awning.
Just search for 9100 awning recall.
