Old 06-12-2015, 04:54 PM   #1
DnL
Backup Camera
I have a Rear View Safety camera system. The backup camera all of a sudden stopped working. I get a blue screen with the words "No Signal". The backup grid still works - and both the right and left cameras still work. Any ideas?
DnL is offline   Reply With Quote
Old 06-12-2015, 06:19 PM   #2
I would check under the drivers side of the dash, there is a small box with all three cameras to plug in. If they are all still plugged in, swap two leads and see what you see. Should eliminate which part is not working.
caesar101 is offline   Reply With Quote
Old 06-14-2015, 12:57 PM   #3
DnL
I did as you suggested - swapped the rear camera with one of the side cameras. The side camera worked; the rear camera did not. So, the problem is somewhere in the camera's cable or the camera itself. We bought the coach new in 2013. I can't image the camera has already gone bad.(?)
