Old 09-21-2015, 05:23 PM   #1
Total Loss's Avatar
Backup camera
I have an aftermarket wireless unit to install.
What is the best 12 volt source to grab off the upper rear of the unit?
Total Loss is offline   Reply With Quote
Old 09-22-2015, 06:06 AM   #2
lakewood90's Avatar
I used a Garmin bc 30 with my gps and tapped into the position light circuit at the upper rear inside. Must have parking lights or headlights on, but feel safer with them on anyway. Currently driving an freelander with cabinets in upper rear of the coach.
Tiffin Allegro Bus 43QRP DP
(Sold)2016 Sunseeker 3010DS
TOADs: Honda CRV and Jeep Grand Cherokee Overland 4 x 4
lakewood90 is offline   Reply With Quote
Old 09-22-2015, 09:06 AM   #3
Total Loss's Avatar
That was my dilemma- I could easily tap into the center clearance light but I would then need at least parking lights on.
May make for a better setup anyway since I can just turn off the light switch easily when I want to switch the camera off.
I was also thinking rear bath fan (rt rear corner).
But then I would have to drill a hole in the roof.
Old 09-22-2015, 11:00 AM   #4
waiter21's Avatar
I used the center marker light. Like you say I need the parking / running lights on but I haven't found this to be a problem.
Rear View Camera | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 09-22-2015, 11:21 AM   #5
Kenny kustom's Avatar
Nothing wrong with having your lights on!!!!!!!!!
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 09-22-2015, 11:26 AM   #6
Total Loss's Avatar
That is probably what I will do.
Easy to switch them on/off at any time and I know when they will be on- when the camera is on.
Thanks for the replies.
