Old 03-31-2015, 06:58 PM   #11
Mikegjax's Avatar
Originally Posted by john.tucson View Post
Is there a way to keep the backup camera on while travelling to monitor our TOAD (2014 Solera 24B) ???
When the key is on just push the "ON" button in the lower corner. I use mine all the time that way in my 24R. You can use it like a rear view mirror if you choose.
Works great.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 04-01-2015, 09:38 AM   #12
GM
bclemens's Avatar
Power button keeps it on all the time.
Audio only while in reverse. (for good reason)
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-01-2015, 02:04 PM   #13
It is the factory backup camera that came with our new solera. Is the connection you are talking about right near the Trailer wiring plug ??? Any major downside to hooking it up as always on ??
saw the power button post after this was posted.... thanks
john.tucson is offline   Reply With Quote
Old 04-01-2015, 04:46 PM   #14
Mikegjax's Avatar
I like having the choice. Some times at night it can be to bright. Then I turn it off until I need it. That is just me.
Most of the time I keep it on.
2014 Solera 24R
USN Retired
Old 04-03-2015, 10:01 AM   #15
Our dealer told us that our 3050s's rear camera had no mic. After seeing this thread, I went back and verified that it does have a mic with the camera. However, the volume has to be turned up to 100, and even then what I hear is just above a whisper. Is there some adjustment I'm missing?
mattnlisa is offline   Reply With Quote
Old 04-03-2015, 10:06 AM   #16
GM
bclemens's Avatar
clogged mic? It's way up on the camera....try being in reverse with someone on the ladder talking in. One way to test it.
Old 04-03-2015, 11:04 AM   #17
We tried ours with same result at 100 percent volume.
Old 04-03-2015, 11:36 AM   #18
GM
bclemens's Avatar
Just to confirm....when testing the vehicle is IN REVERSE correct? That is the only time that the volume will work. It is also ONE WAY. Outside to inside, not inside to outside.
Old 04-03-2015, 04:10 PM   #19
Mine is also a whisper at 100. So I resort to FR handheld then at least I can talk to the DW and she can respond, sometimes even favorably
Roger64 is offline   Reply With Quote
Old 04-03-2015, 04:55 PM   #20
Where is the mike located on the camera, Our unit was full body paint and I wonder if my mike is somewhere under the paint...
