Old 09-15-2016, 11:32 AM   #1
Hoglou's Avatar
bath faucet swap
Replaced OEM bath unit with a house unit. Tools needed are a basin wrench, flashlight, and QA from DW (more later on that topic). Took 15 minutes, but leave it under shore water pressure over night (suprize me at home where the tools are, and not on the road). I did use the OEM faucet nuts as they were thinner allowing more thread for the waterlines.
Most bath faucets have a plunger knob. I cut about seven inches off the stem and added a 1/2 of plastic tubing to the stem on the underside of the faucet, could just drill a small hole to let the stem drop down in the sink.
So after the install DW said why not put drop of glue on the stubby knob and push it in, if it becomes loose in the future just reglue it. DW common sense trumps eng degree..... again.
ID:	120278   Click image for larger version
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 09-15-2016, 01:01 PM   #2
sgtlm17's Avatar
This is on my list of mods to do. I hate the plastic faucet in the bath. Feels like im going to break the faucet everytime I use it.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 09-15-2016, 03:39 PM   #3
WFD
Just did ours as well, was as equally simple as yours. No more squeaking. Once I got the plastic one off and examined it, I couldn't believe how cheap it was. Every bit of it is made of plastic.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 09-15-2016, 03:54 PM   #4
Soon after we got our Sunseeker I replaced both the kitchen and bath sink fixtures with residential single handle units. The single handle is especially good for the kitchen sink. When rinsing dishes by turning on only hot water it was too hot. It was inconvenient to turn both hot and cold faucets. With the single handle I can set the mix to a comfortable temperature.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 09-16-2016, 06:02 AM   #5
Wait till next year...
n-e-d's Avatar
Like Rambler Guy replaced bath faucet and shower with single lever because hot water was too hot and easier to mix with the single lever. Read a thread in the Forester forum about an adjustable thermostat for the hot water heater.Install was quick and made a big difference especially in the shower
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
n-e-d is offline   Reply With Quote
Old 09-16-2016, 07:32 AM   #6
I just picked up bathroom faucets yesterday.
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
hockeytownmom is offline   Reply With Quote
Old 09-16-2016, 07:33 AM   #7
X2.
SkipnTerri is offline   Reply With Quote
Old 09-16-2016, 07:42 AM   #8
I glued mine, too, after I cut off the stem.
Anne
Jim & Anne
2017 CC 38EL
JAClend is offline   Reply With Quote
Old 09-16-2016, 07:59 AM   #9
Single lever,No stem,No plastic! Youroo!!
Old 09-17-2016, 08:59 AM   #10
Chief tinkerer
Gidyupgo's Avatar
Joining the "show us your faucet" club. Currenty set to dispense 12oz per push. Great for the grands.
ID:	120437   Click image for larger version
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 09-17-2016, 09:06 AM   #11
Have grandkids that camp with me, know I will have to make this mod.
Steve29rlx is offline   Reply With Quote
Old 09-17-2016, 09:48 AM   #12
sgtlm17's Avatar
What type of single lever faucet did you use for shower?
2011 Jeep JK Toad
Old 09-17-2016, 10:16 AM   #13
Chief tinkerer
Gidyupgo's Avatar
Steve, speaking of grands, we also cracked open the waterheater bypass part way to lower the hot water temp at the faucet.
Gary
Old 09-25-2016, 07:15 PM   #14
Senior Members
Butch & Lena's Avatar
How hard was it to do. Did you just reconnect the new faucet with the old PEX connections? My sink is set up just like you have. When I look under the sink, what a tight space to work in. Any suggestions would be appreciated. Thanks.
Butch & Lena is offline   Reply With Quote
Old 09-25-2016, 08:00 PM   #15
Chief tinkerer
Gidyupgo's Avatar
Bath faucet swap
For mine, PEX hooked right up. Had to use a rotary file to enlarge the holes. Tip, the cabinet wall nearest the door has an open top. If you drop one of the retaining nuts down there it's a bear fishing it back out. Go for it!
Gary
Old 10-01-2016, 02:00 PM   #16
Senior Members
What is the diameter of the PEX tubing in your MH? Thanks.
Old 10-01-2016, 08:44 PM   #17
Chief tinkerer
Gidyupgo's Avatar
Believe it is 1/2.
Gary
Old 10-04-2016, 05:23 PM   #18
Chief tinkerer
Gidyupgo's Avatar
butchs, if you haven't done this yet, I wish I would have picked up a couple of push on PEX to 3/8 shutoff valves when I put mine in. I did, when I changed the kitchen faucet.
Gary
Old 10-05-2016, 11:17 AM   #19
Senior Members
I did pick up the 1/2 to 3/8 shut off valves for the bathroom and kitchen. Thanks. Makes for a easy change.
2015 3010DS Sunseeker
2010 Jeep Wrangler Unlimited
faucet
