Originally Posted by newRVer
Have you checked to see if you rig is actually level? The big foot leveling system we have was way off level when it was delivered to us and one of the first things I did was re-calibrate the system. Much Much better now.
PS. I noticed that once I re-calibrated the RV so that it was actually level, our front entry door would stick considerably to the point where I had to file down the metal catch on the door jamb to allow for easy opening and closing.
Yes, I check for level both directions after the Bigfoot says it's level. We also assumed that when we picked up our new Forester that it would have been calibrated at the factory....WRONG! Since then, we had it calibrated and now it's accurate, but we still get the bathroom door problem. I may have to re-work the door catch, although it will probably look like a monkey with an axe did it when I get done! I also don't like it when both front wheels are off the ground.
By the way, don't expect to get re-imbursed by FR Warranty for calibrating the Bigfoot...they say it is a "maintenance issue".
