Old 06-04-2017, 08:25 PM   #1
hockeytownmom's Avatar
Batteries aren't charging
I was plugged into shore power all weekend, battery disconnect was in the on position. Got home and within a 1/2 hour the indicator was showing empty. What could be causing this?
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 06-04-2017, 08:32 PM   #2
A32Deuce's Avatar
Use a volt/multi meter to check your battery. Then check output of converter with battery off. One or the other could be bad.
A32Deuce is offline   Reply With Quote
Old 06-04-2017, 08:57 PM   #3
bikendan's Avatar
Technically, when a disconnect switch is "engaged/on", it is disconnecting the battery from everything.
And when it is "disengaged/off", it reconnects the battery to everything.
Equalizer WDH
Old 06-04-2017, 09:20 PM   #4
A32Deuce's Avatar
I believe he,ment the Bats were on!
Old 06-05-2017, 12:32 AM   #5
benagi's Avatar
My 3171 charges with disconnect on or off when plugged into shore power. Check with a meter. Your batteries should read 13v or more when plugged into shore power. As far as to why they aren't charging others will have to chime in and point you in the right direction .
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 06-05-2017, 07:36 AM   #6
A32Deuce's Avatar
Opposite. When mine is on the bats are connected. Just like on a drag car, on/off
Old 06-07-2017, 08:19 AM   #7
I would suggest that you have a bad battery(s) that could have a shorted cell draining them quickly. As suggested, need to see if they are charging first. If you are plugged into shorepower and the monitor lights go to 100% charge, chances are the converter is putting a charge to the batteries ( although not for absolutely sure).
ActionJackson is offline   Reply With Quote
Old 09-20-2017, 12:06 PM   #8
Check to see if your vehicle chassis battery is being charged. It should receive about the same voltage as the coach battery if the charger system is working. Look for a small circuit breaker in the wiring around the battery box area and push the button to make sure it has not tripped off.
Underdog is offline   Reply With Quote
Old 09-20-2017, 12:17 PM   #9
2012 Solera
From comments on the forum, I think Forest River changed the converter connection when they switched to the Progressive converter (from the WFCO).
On our 2012 Solera (WFCO converter) the battery switch has to bo "on" for the converter to charge the batteries. As I understand, on more recent units (with Progressive converters) the batteries will charge whenever connected to shore power, independent of the battery switch position.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 09-27-2017, 06:39 AM   #10
trdutch's Avatar
Stock battery's are junk.
Mine were replaced with Interstates after one year and I was able to get $100 rebate from the original Battery manufacturer.
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 09-29-2017, 07:57 AM   #11
Garrette's Avatar
Please post the fix, inquiring minds want to know.
Check the circuit breaker to the battery charger Push the breaker all the way down and than back up to reset. Breaker is located in the breaker panel and is marked.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 10-23-2017, 01:27 PM   #12
I bought new house batteries today and installed them.
Kristina & Family
Old 10-24-2017, 12:10 PM   #13
Senior Members
Butch & Lena's Avatar
What kind of batteries did you buy?
2015 3010DS Sunseeker
2010 Jeep Wrangler Unlimited
Butch & Lena is offline   Reply With Quote
Old 10-25-2017, 01:58 PM   #14
Oh crap, I don't remember. It's been a busy crappy week. They are holding a charge, so I'm happy.
Kristina & Family
Old 10-25-2017, 07:40 PM   #15
Senior Members
Thanks for the helpful info.
batteries, charging
