Old 02-20-2016, 04:14 PM   #11
Sagecoachdriver's Avatar
Making Sense now
Went to Napa and bought a top terminal mount and attached to positive post. Ran the Converter/Charger cable to it along with the Solar input from the controller along with the battery monitor shunt power connection.
Attached the cable from the alternator, Battery cut-off/Generator and battery link to the screw post. I tried attaching all four cables to the screw post and barely got them on with great difficulty. It totally blocked access to the battery caps preventing easy checking of water levels and SG. So that's why I purchase the top post terminal connector. All the values on the clamp-on amp meter now make sense.
Things learned
Battery cut-off and generator are on the same cable. However, the cut-off doesn't prevent use of the generator at any time.
Converter Charger will charge the house batteries when plugged in to shore power regardless of cut-off switch position.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 02-20-2016, 04:36 PM   #12
camaraderie's Avatar
Nicely done...neat & clean now!
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 02-20-2016, 05:04 PM   #13
sgtlm17's Avatar
If anyone has the Bigfoot Jacks they will also have a positive connection directly to the battery
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 02-20-2016, 05:16 PM   #14
I have BigFoot jacks and when I attached the alternator cable from the relay to the battery, the BigFoot panel lit up. I believe there must be some relays and solenoids inline as the engine being on will trigger the BigFoot alarm if the jacks are down and the lights stay on while the engine is on. I'm charging my batteries right now, but later I can check it more thoroughly and disconnect that cable marked alternator and see if that affects the levelers.
Old 02-20-2016, 05:55 PM   #15
sgtlm17's Avatar
On mine (2016) one of the red cables to positive is marked Bigfoot Jacks. I just got my unit and haven't examined it any closer
Old 02-20-2016, 06:17 PM   #16
Mine is a 2016 also, but probably an earlier build than yours. Since there are so many variations of the 12v electric, it's no wonder that FR doesn't give out diagrams and schematics.
Curious, can you take a photo of yours? I'd like to see how your battery cables differ. Always a learning experience here on the forum.
Old 02-20-2016, 06:45 PM   #17
sgtlm17's Avatar
I sure will. I'll be out in rig in a bit. Mine was built in December 2015 picked it up last week. And your right about different variations
Old 02-20-2016, 07:40 PM   #18
sgtlm17's Avatar
Ok here's a pic of my battery wiring. On left positive post is converter positive cable and battery positive cable. On the positive post on the right is the power jack positive cable. Of course the small positive wire in the center connects the two batteries.
Correction unit was built January 2016.
Old 02-20-2016, 09:45 PM   #19
So mine was wired like yours is. The Power Jack cable on yours was what I thought was the alternator/ leveler as my bigFoot panel lit up when attached to the battery. It was in the same location.
So where does the alternator make it's connection to the house batteries for charging and engine battery boost when needed? I would still think it's the power jack cable with relays and solenoid.
Challenging isn't it?
Joshua Cavitt, feel free to interject at any time.
Old 02-21-2016, 08:09 AM   #20
forgive my ignorance, but with the shunt wire (the wire between the two batteries) does that make both terminals in effect the same? could you not connect a couple of your reds to the other terminal? Maybe I'm not understanding the problem. If so, please ignore.
fastwilly is offline   Reply With Quote
wiring, battery
