Old 02-27-2017, 09:38 PM   #1
Battery drain???
Have a 2016 Forester 3011DS, front entertainment center. Have had an issue with the batteries going down significantly even with the battery disconnect on. Nothing should be drawing the battery down in such a short time (matter of days).
It is currently at the dealer (have done very well for me so far). They show a 3 amp draw, with the battery disconnect on. They have pulled all fuses (one at a time) in both fuse boxes and identifies the draw. Still show a 3 amp draw on the batteries. None of the fuses showed what the problem is.
They are still looking but just wondered if anyone has any ideas what the problem might be??? 3 amp draw even with the battery disconnect on.
Hmmmm
Any suggestions or comments appreciated.
Due to depreciation the above opinion is now worth less than what you paid for it.
Everyone is good at something... I happen to be a good bad example.
2016 Forester 3011DSF
Oregon is online now   Reply With Quote
Old 02-27-2017, 10:08 PM   #2
I've read on here that there will still be a slight draw with the disconnect on. I started shutting the main 30amp circuit breaker also. I just started doing the a few weeks ago, so I'll know if it did anything when I go to start up the generator next week.
Brian217 is offline   Reply With Quote
Old 02-28-2017, 01:17 AM   #3
benagi's Avatar
I have the same problem on our 3171. I either disconnect one negative cable or hook up a battery tender.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 02-28-2017, 07:11 AM   #4
A 3A draw with the disconnect on is a lot. Since you had all fuses pulled and still saw the draw, then I would start looking at items that are directly connected to the batteries such as levelers if you have them.
newRVer is offline   Reply With Quote
Old 02-28-2017, 07:20 AM   #5
NMWildcat's Avatar
I would just put in a cutoff between the negative post and the frame ground point. Done.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 02-28-2017, 07:45 AM   #6
Herk7769's Avatar
While this may solve the storage problem, a 3 amp draw with the disconnect on needs to be tracked down. The OP will have a hard time boondocking with a phantom 3 amp draw.
You may need to trace wires to make sure that only items that are supposed to be on the "always hot" circuit are on it; and someone did not take a shortcut and add something else.
HAM CALLSIGN - KC3FFW
Old 03-01-2017, 05:44 PM   #7
Just for the record --- dealer called said they fixed it. Not sure how or why but it's fixed.
Said they did all the fuses and then started tracking individual wiring. Said they found one that was black and white but not sure what it was for. Called Forest River and got electrical schematic. Appeared that wire should be for either the outside lights, the awning or another light that I forget where/what it was.
They disconnected the wire and viola the draw went away.
BUT, there was an issue as ALL the lights still worked, the awning worked and they couldn't find anything that didn't work!
Dealer said the factory said it was a phantom draw. Apparently something that happens rarely but occasionally and to leave it capped off (shouldn't be a problem). Dealer is stumped but said they've tried everything electrical on the coach and it all still works.
I'm just glad they fixed (?) it and guess we'll just see if I can find anything that doesn't work when we go out next month (first trip for 2017). With my luck the toilet won't flush and somehow it'll be because of that wire.
Old 03-01-2017, 06:00 PM   #8
johnbryanpeters is offline   Reply With Quote
Old 03-01-2017, 06:18 PM   #9
WolfWhistle's Avatar
If I were you, I would like to see that schematic. If there is one for your unit, it will be a first. FWIW, I have .2 to .3A draw with battery disconnected (OEM) which the only thing that's there is the slide controller. I thought the CO detector was part of that load, but it turns out it runs on a 12v light circuit, which the disconnect removed. So, now I have a disconnect that allows me to split the batteries (have 4 GC-2s), run all or disconnect completely. But, I very very seldom disconnect... just while performing maintenance.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 03-01-2017, 09:23 PM   #10
i'd sure want to know what is going on. 3 amps really does sound way out of line for a phantom draw. and things like lights and awnings really shouldn't be part of a phantom draw as they are controlled by off / on switches. when their switch is off they are not connected to the battery. are you the original owner or has a previous owner had the opportunity to 'improve' the factory wiring?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
battery, drain
