Old 12-30-2018, 09:18 PM   #61
Originally Posted by Sagecoachdriver View Post
Yes, but it is the last battery I will have to buy.
Famous last words
TV - 2020 RAM 3500 Mega Cab SRW with 6.7 Cummins HO & Aisin 6 spd, 4k payload, 23k towing
2002 GMC Yukon XL 2500, 8.1 liter (496ci), 4L85e & positraction with 3.73 gears
TT - 2013 Dutchmen Aspen Trail 3130 QBS
Great bourbon-just about any of San Diego’s craft beer
Beachbourbon is offline   Reply With Quote
Old 12-31-2018, 02:11 AM   #62
Babcock, if lithium batteries are 70 amps DOD would my PD4560 charge them at the full 60amps rate less what ever line loss there is. Reason I’m asking is currently they are charging at about 35amps with that converter charger with the flooded.
Yes...full 60A. I can even demonstrate this for you. If my converter put more than 60A out, it would be even more.
babock is offline   Reply With Quote
Old 12-31-2018, 10:14 AM   #63
Sagecoachdriver's Avatar
Thanks, may take you up on it.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 12-31-2018, 05:37 PM   #64
PM me.
Old 01-01-2019, 01:23 PM   #65
DavidBo's Avatar
I found this after a bit of research. It's apparently intended for motorized wheelchairs but the specs look intriguing.
https://www.walmart.com/ip/VMAXMB127...tery/466932935
A bit pricey, but I like the durability. The measurements are right in the group 27 spec.
DavidBo is offline   Reply With Quote
Old 01-01-2019, 01:26 PM   #66
They are great batteries. We used one for my mom's camper.
Old 01-04-2019, 10:14 PM   #67
We may ghave o to Quartzsite in two weeks for the annual RV show. I see Battle Born batteries has a booth. Perhaps they will have further discounts on the Lithium batteries.
Old 02-15-2019, 09:40 AM   #68
Has anyone been able to get 2 Group 31's into the battery compartment in the step-well of a Forester or Sunseeker?
I went to Costco and got two 27's and called it a day. I've got 36 months to try them out.
2016 MBS Forester 2401R
baranski is offline   Reply With Quote
Old 02-15-2019, 09:50 AM   #69
A32Deuce's Avatar
I have 2 Optima group 31 in the step of my SunSeeker.
A32Deuce is offline   Reply With Quote
Old 02-15-2019, 11:11 AM   #70
I have had other issues come up in the past few months. Since the house batteries are still working fine, I've put them on the back burner for the time being.
Old 02-15-2019, 07:19 PM   #71
Garrette's Avatar
Yes, but just barley. I have 2 group 31 Duracells from Sams installed. 3 years old and still doing well.
Garrette is offline   Reply With Quote
Old 02-17-2019, 01:51 AM   #72
fritzteuscher's Avatar
Originally Posted by gmclean View Post
If you check the last photo you can see I mounted the shunt on top of the batteries. Works great
What’s a shunt, and why do you need one?
Fritz Teuscher
CDR USN (Ret)
2019 Forest River Forester MBS
fritzteuscher is offline   Reply With Quote
Old 02-17-2019, 01:56 AM   #73
The shunt is used with Battery monitoring systems to allow it to read the voltage , amps charging and draw. Mine is connected on the negative side and all battery hookups are made before the shunt so it can accurately work.
Old 04-12-2019, 06:46 PM   #74
Originally Posted by derek6669 View Post
I have a Sunseeker and last spring purchased 2 Group 31 batteries. They fit with a "little" room to spare.
What model Sunseeker do you have, and what was the brand name of the batteries, thanks much!
TEC1957 is offline   Reply With Quote
Old 04-12-2019, 07:38 PM   #75
derek6669's Avatar
we have a,2008 Sunseeker . Batteries purchased from Canadian Tire Batteries are Motormaster RV/Marine
derek6669 is offline   Reply With Quote
Old 04-14-2019, 03:23 PM   #76
Filterman's Avatar
Our GRP 27 Interstate are in their 8th season and still going strong. For that reason I will replace them with the exact same battery. We do a lot of boondocking but I’m anal about not letting them go flat. I run the generator hour or so each morning and evening and I’m convinced that contributes to their long life.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
Filterman is offline   Reply With Quote
Old 04-19-2019, 08:21 AM   #77
ejohnson1144's Avatar
I agree
ejohnson1144 is offline   Reply With Quote
Old 04-21-2019, 08:17 PM   #78
On the interstate 31 what is the CCA and MCA numbers
retired on a mountain is offline   Reply With Quote
Old 04-22-2019, 08:30 AM   #79
I think they oEM batteries may be starting there slow demise. After 5 days at the beach the system has been hooked up with shore power and solar for the past 10 days. I checked the SG and it only says 1275 instead of 1300 which it has been inb the past when fully charged. I did an equalization a couple of months back using my solar controller. Not a lot of variation is SG readings, so bad cell yet. Neighbor has Battle Born LiFePO batteries and highly recommends them. But I would have to change out the Solar controller and the Intelli-power converter charger. Big expense of $2,200 and a some electrical work.
Old 04-23-2019, 07:38 PM   #80
1.275 is normal
battery, forester
