Old 07-13-2015, 12:36 PM   #1
DnL
Battery Voltage
I know there's lots of threads on this general topic, but I can't find one that addresses this specific question. Why is the voltage reading different when the batteries are disconnected from the coach verses when they are connected? When I disconnect the batteries and test them with my multimeter they each (two of them) read 12.69 volts. When I connect them to the coach (which has a converter) they read 10.54 volts. (Using the same multimeter for all tests.)
DnL is offline   Reply With Quote
Old 07-13-2015, 12:40 PM   #2
fr1rd831's Avatar
Could mean a loose wire somewhere. Where are you testing when connected?
Ray and Maria
Lincoln CA
Our Forest River Gallery & Family Photo's link
fr1rd831 is offline   Reply With Quote
Old 07-13-2015, 12:41 PM   #3
How much current are you pulling when you are connected.
It looks like you have weak batteries or you are pulling a lot of current.
If you only have the minimum turned on in the coach you should only see a couple tenths of a volt change.
Ontario
Current: 2019 Sunseeker 2290S
Previous (2012-2016): 2012 Vibe 6501
1 Prospector Canoe, 2 Mtn. Bikes & 4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 07-13-2015, 12:44 PM   #4
fonzie's Avatar
do you have an inverter and residential fridge in your coach?
Fonzie
Old 07-13-2015, 12:52 PM   #5
DnL
Those readings in my original post were taken at the battery terminals. When the batteries are plugged in I get the same reading using a cigarette plug voltage meter in a socket inside the coach.
When I plug into shore power the readings go up to 13.63 at both the batteries and plug.
Old 07-13-2015, 01:52 PM   #6
DnL
Happy Vibe: Everything is turned off, so the only things that should be using current (that I can think of) are the CO/Propane detecter, TVs in their off condition, and the clock in the Magnadyne entertainment center.
Old 07-13-2015, 01:54 PM   #7
DnL
Fronzie: I have a converter - no inverter. My fridge is not the residential type - and the one I do have is turned off.
Old 07-13-2015, 01:58 PM   #8
Flybob's Avatar
Sounds like something is drawing current. Pull one fuse at a time and remeasure voltage at battery. This should help you narrow it down.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-13-2015, 02:46 PM   #9
If the batteries are good and fully charged it would take a vary large current draw to bring them down to 10.5V. so if you have the batteries on and reading 10.5V and then turn them off how fast does the voltage return to 12.6ish volts?
Ontario
Old 07-13-2015, 05:43 PM   #10
DnL
Flybob: good idea about pulling the fuses. I'll give it a try.
Old 07-13-2015, 05:46 PM   #11
DnL
Happy Vibe: the voltage goes back up immediately - the amount of time it takes to flip the disconnect switch and get the multimeter probes on the terminals.
Old 07-13-2015, 08:03 PM   #12
I have two trains of thought. 1 you have a defective battery that has high internal resistance so as soon as you put any load the voltage at the battery drops or you have something in the RV that is drawing a lot more current than you think. The pulling fusses should tell you if it is the latter.
Ontario
battery, voltage
