Old 10-01-2015, 08:31 PM   #1
Beeping from under steering wheel
Just picked up my 2015 Forester from storage and five minutes into drive home a beeping started from under my steering wheel. Pulled over and checked all alarms in the back and nothing was going off. Only thing different about this trip was it is the first time I had the dashboard heat on. turn ignition off, and beeping stops. Help!!!
steveadamcik is offline   Reply With Quote
Old 10-02-2015, 01:04 PM   #2
Wandering's Avatar
Sounds like a warning beep. Either a door is open or brake is on?
Forester 2451s
Wandering is offline   Reply With Quote
Old 10-02-2015, 01:11 PM   #3
Assistant TP Supervisor
B and B's Avatar
Slide not fully retracted?
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 10-02-2015, 01:14 PM   #4
If you have Bigfoot levelers, could be it
GJones is offline   Reply With Quote
Old 10-02-2015, 01:55 PM   #5
Exclamation Beeping help
I also have a F250 Ford p/u and I pull a Cedar Creek Silverback 29IK. Mine started doing that and it turned out to be a dirty pin in my rv wiringhook up. Also make sure the plug is in ALL the way.
Bluesky is offline   Reply With Quote
Old 10-02-2015, 01:56 PM   #6
It is a Trailer Disconnect Warning by the way.
Old 10-02-2015, 07:17 PM   #7
It's warning that one of your levelers has dropped a small amount. Hit retract all levelers and you will be good to go.
First time it happened to me, I spent hours tiring to figure out where the beeping was coming from.
Ed & Gay
Mini-Schnauzers Dora & Mabel
(Phoebe, in our hearts)
2014 Forester 3051s
2013 Fiat 500 Sport
Workin on my Curmudgeon badge
rapiniii is offline   Reply With Quote
wheel
