Old 01-24-2016, 02:28 PM   #31
We have a 2013 Sunseeker and I drove to Bigfoot to get the fully auto system installed aftermarket. If I had it to do over, I'd probably opt for the manual system. Here's why... I recalibrate for true level at least once a season. But it's not perfect (I am, admittedly, a bit of a perfectionist). It is always off a little. If I'm staying in a place for longer than a night, I usually level manually. I have a bubble level. But I base level on the bathroom door (if it stays open in its own in the middle of the swing). Now on an overnight stop or if it's raining, auto level is just fine. The other advantage for manual is it seems that the jacks extend too far at times on auto and you can control that more on manual. Just my two cents.
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 01-25-2016, 08:01 AM   #32
Class C Representative
Joshua Cavitt's Avatar
We knew we were making the change to a different set up, we didn't know it wasn't going to be a full auto-leveling system and didn't find out until after the fact. It didn't have to do with people not paying attention on the line or in QC.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 01-25-2016, 10:44 AM   #33
The automatic has manual mode too, right? You have to press two at a time to retract?
jovialjeeper is offline   Reply With Quote
Old 01-25-2016, 03:36 PM   #34
There is a manual option on there as well.
Old 01-30-2016, 08:33 AM   #35
As Joshua said, auto has a manual option. You press two at a time when leveling (the fronts, backs, lefts, or rights). You just press retract to come down (all four retract at the same time).
Old 01-30-2016, 10:29 AM   #36
KJcachers's Avatar
Originally Posted by Boso View Post
Auto leveling but usually have to use manual after the self leveling has stopped to get the front end high enough to be level
Have you ever programmed your system? I found the steps to zero it out and reprogram for level but haven't tried it yet. Mine still needs a nudge to get the front up to level. Hoping the programming of the unit will fix this.
Jason and Karen
2015 Forester 3051S
2016 Ford Fiesta-Toad
https://www.visitedstatesmap.com/image/NCTNVAsm.jpg
KJcachers is offline   Reply With Quote
Old 02-02-2016, 12:07 PM   #37
Sagecoachdriver's Avatar
My Platinum levels side to side.
I have always used my Platinum levelers by manually lowering each foot to the ground and then slowly leveling each corner as told by tech at BigFoot. Yesterday, I thought I would try the semi auto method by hitting POWER then START. But first I checked the level and it was lower on the front and drivers side. I started leveling and the feet all dropped, the front wheels came off the ground a little while the rears raised slightly but were still on the ground.
I checked the level and to my surprise, the front to rear was way off and low on the front. The side to side was now level. Perhaps, this prevents twisting of the frame.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 02-05-2016, 01:20 AM   #38
As it turns out, our 3171 also did not come with the fully automatic leveling system. Camping World says FR is the worst manufacturer for sending out parts and it will take four weeks to get whatever they need for the retrofit. If we hadn't seen this thread, we wouldn't have known about the jack issue. (This is our first RV.) I don't think FR is doing anything to notify customers as they never contacted us about it. Thanks to the folks here for alerting us to the issue. At least FR is going to pay to fix it -- now that we have brought it to their attention.
Pixey is offline   Reply With Quote
Old 02-05-2016, 08:50 AM   #39
When a dealer says that it turns out they haven't even placed an order for them. If it is a small item they will wait for a bulk order so they can mix it in to the shipping cost.
Old 02-05-2016, 10:37 AM   #40
My dealer said for me to contact FR direct and ask about getting the upgrade to full auto. I sent an email on Monday, so far no reply. Have my Forester 5 months now. Hope it's not too late.
leveling
