Old 07-28-2015, 06:08 PM   #11
vwexpert's Avatar
I always do a walk around the coach before driving away - checking antennae is down / jacks are up / and I use a broom handle to poke the rear inside tires to verify they have air.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 07-28-2015, 07:11 PM   #12
Creativepart's Avatar
We do just that - get a visual on the jack feet before any movement.
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 07-28-2015, 07:19 PM   #13
Originally Posted by wesslvm View Post
I always power mine off. My controller is under my driver seat so I'm trying to make sure I don't accidentally actuate it.
x2. Always turn system off being it turns on once the engine is started. Picked up a cheap plastic box to keep it in and covered so buttons aren't accidentally pressed.
SkipnTerri is offline   Reply With Quote
Old 07-30-2015, 12:09 AM   #14
Sagecoachdriver's Avatar
Thanks for the tip Benagi. Anyway to photo that pin?
Sagecoachdriver is offline   Reply With Quote
Old 07-30-2015, 12:20 AM   #15
benagi's Avatar
Will do tomorrow, if some doesn't do it before me.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 07-30-2015, 06:53 PM   #16
benagi's Avatar
Sage, here is the picture you asked for. The pin in question is on the right side of this jack.
1968 tent trailer
1985 Jamboree 23 ft
Old 07-30-2015, 09:24 PM   #17
One of my pins on the plunger switches was bent. Every 30 min or so the jack would bleed off a millimeter or so and cause the control panel by the door to beep at us. Dealer ordering a new one. Kids have to take turns pressing retract all while on the road.
steverkemp is offline   Reply With Quote
Old 07-30-2015, 10:11 PM   #18
Thanks Ben for the photo. Now I understand.
Steverkemp, wasn't there a way to disconnect power to the levelers and stop the alarm? Or wouldn't that help because the levelers was dropping? How did the pin get bent?
