Old 07-06-2016, 10:32 PM   #191
BEFUDDELED MEMBER
Originally Posted by Boso View Post
I went with the roadmaster reflex steering just because it was on sale and the reviews were good I didnt want to take a chance on the bilstein and have that pulling problem just the safest and easiest way to go for me but there are a lot of options as far as different manufactures still hoping airbags are fixed when I get RV back
The Ford stabilizer tie rod end mounts the same as the Roadmaster. The tie rod end bracket is mounted with U bolts same as the RM. It is centered the same as the RM to compensate for L or R pull.
The Bilstein's are a viable alternative and fully adjustable.
13,SUNSEEKER 3010
RETIRED / New Mexico
KZ5PZ - EXTRA -
Viet combat vet USNR
DAV, VFW, CCL. SASS
shooter2 is offline   Reply With Quote
Old 08-22-2016, 01:19 PM   #192
Originally Posted by vwexpert View Post
Bringing back an old thread...after alignment, installing shocks, and sway bars my coach started wandering. I took it back to the alignment shop and discovered the specs in the left front changed. The coach had a lot of positive camber and was toed out. We believe the two piece camber / caster adjusters slipped / moved. I also noticed the caster was only at 2.5 degrees. The tech said that was were he set it. Well that started a long discussion on motorhome front end alignments. He said a lot of caster will screw up camber and cause tire wear. I ended up going over to another alignment shop and got 2 - 2 1/4 degree camber / caster adjusters (one piece) - made the tech throw on those bad puppies and now I got 5.3 on the left and 6.1 on the right (and it kept the camber within specs). My coach was handling ok but sometimes it would just wonder off right or left. Taking it out for a 3 hour drive next weekend to verify...
VW, did you get a chance to take that 3 hr drive yet? If so, how did your vehicle perform after installing the kit?
newRVer is offline   Reply With Quote
Old 08-22-2016, 04:51 PM   #193
vwexpert's Avatar
newRVer...yes I took it out for the 3 hour cruise...it handles like a 7 ton SUV.
Much better than stock. I'm very happy with the handling now.
Jim
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 08-23-2016, 08:29 AM   #194
Jim
Good to hear! I bought the same caster set that you had installed and will going for an alignment tomorrow. Hopefully I will have similar results.
Old 08-26-2016, 11:46 AM   #195
Sagecoachdriver's Avatar
Not happy with the Roadmaster ride
After 5 trips, I'm not happy with the steering with the Roadmaster Reflex. Seems to have too much wandering again and I have increased effects from wind and passing vehicles, even small cars.
I prefer the heavier control of the Bilstein. May but it back on today and try in for a few trips.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 0trips 0 nights
Sagecoachdriver is offline   Reply With Quote
Old 08-27-2016, 01:08 AM   #196
benagi's Avatar
Sage, I just put a Bilstein on our unit along with the front and rear helwig sway bars. Driving much better now. Still need to do the front end alignment though.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 08-27-2016, 07:28 AM   #197
No-Fish's Avatar
Sage, After one trip from Memphis to Gulf Shores, and back ( 2 handed, fighting the wheel) in our new 3011, I had the front align, and replaced the steering damper to a Bilstein, no more steering bump. Went back to Gulf Shores, towing a toad, one hand drive, drove like my F350, coming back to Memphis, had a west wind all the way back..still held the road great
No-Fish is offline   Reply With Quote
Old 08-27-2016, 11:54 AM   #198
Did put the Bilstein steering damper back on yesterday. Good thing as I found that the frame bracket lower bolt had become lose and has strip some of the threads. Not usre if I had over or under tightened the Roadmaster Reflex. I have the bolts on fairly tight but I am going back to the alignment shop Tuesday. When I called for the appointment and mentioned the bolt, he said no problem. Driving over to get gas, I felt less centering as to be expected but about the same steering tension. It drove straight as an arrow where as the the RM Reflex was wandering.
So Benagi, did you find that the sway bars helped with wind and passing vehicles? Do you have the part numbers for the sway bars?
Old 08-27-2016, 03:18 PM   #199
Forester Fred's Avatar
Originally Posted by Total Loss View Post
Finally tested the rig (Chevy) with the new goodies. No wind conditions.
1) Alignment- much better- less wandering
2) Roadmaster Reflex install- Much straighter tracking. Does not wander with road level changes- works great in combination with the alignment and one handed driving is easy.
3) Bilstein front shocks- no more bounce particularly on freeway overpass transitions where the tarmac meets the concrete.
All in all- 2 thumbs up with the mods. About $500 total - without my labor.
Well worth it.
I should say though that steering is "harder" on slow speed turns.
Total Loss - FR has alignment specs listed for the Ford chassis. Is there anything special for the Chevy 4500 or just go with Chevy specs? I've got 12,000 miles of bumping, potholes and rough roads so I'm figuring an alignment might be some good preventive maintenance at this point.
Also, I'm looking at getting Bilstein shocks. I see they list the comfort and standard models for Fords but only have one listing or the Chevy 4500, which they list as heavy duty. Are the heavy duty models going to be too stiff on a Chevy with a 25' coach?
2015 Forester 2301 - Chevy
Skip & Deb - Denmark, ME & Delray Beach, FL
Forester Fred is offline   Reply With Quote
Old 08-27-2016, 05:30 PM   #200
vwexpert's Avatar
Sage...Amazon has the sways - 7718 front $200.00 / 7180 rear $230.00. Did you ever have the alignment re-done to get a higher caster angle?
Jim
