Old 09-03-2016, 10:18 AM   #221
Sagecoachdriver's Avatar
Any need for an alignment after the install?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-03-2016, 11:01 AM   #222
No need for alignment
My shop said i didn't need an alignment when they put Hellwig on front and back. After 4000 miles on the new suspension i haven't noticed any alignment problems.
2016 Forester 3051SF
MMulcahy is offline   Reply With Quote
Old 09-03-2016, 01:37 PM   #223
Got the front Helwig sway bar a few minutes ago. Yeap, Benagi you're right about the shipping box taking a beating. Everything in there.
Now to decide wether to do it myself or have the alignment shop install it. Going to be a long weekend to decide.
Old 09-04-2016, 01:45 PM   #224
Front sway bar attaches to this?
The existing sway bar ends are attached to these rods, will this rod withstand the new heavier Helwig?
Old 09-05-2016, 12:15 AM   #225
benagi's Avatar
The front helwig swaybars connect to the factory rods. The rear helwig swaybars come with new connecting rods. The rear bar is much heavier . Mine are working fine and loving the ride so far. Off to Colter Bay in the Tetons next weekend.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 09-05-2016, 12:23 AM   #226
Thanks Ben, the rods looked mighty thin on the front. But I guess that's they way they come.
We've been up to Colter bay 3 or 4 times on the way to Yellowstone and Glacier. We've got to get back up there in the next year or two. Maybe stop by and say "hello" on the way. We usually stay at Cabela's in Lehi over night. Are you close?
Thanks again and have a safe trip!
Old 09-05-2016, 12:54 AM   #227
benagi's Avatar
We are only about 20 minutes from Cabelas. Would like to meet you the next time you are passing thru.
1968 tent trailer
1985 Jamboree 23 ft
Old 09-10-2016, 05:03 PM   #228
Taking it into the shop for sway bar
Tried taking the old sway bar off. Could only get 3 bolts out. Gave up and now I am having a very very hard time getting the last big bolt back in. I'm too old for this stuff. Leaving it to the pros!
Old 09-13-2016, 12:36 AM   #229
benagi's Avatar
We noticed when removing the two front bolts, they had loctite on them. We used a 1/2 ratchet and socket and lots of elbow grease as we use to say.
Question about the bilstein steering stabilizer. After installing, we have noticed a little pull to the left when driving. Anyone else noticed this?
1968 tent trailer
1985 Jamboree 23 ft
Old 09-13-2016, 09:15 AM   #230
Total Loss's Avatar
Are they gas charged?
Do they push out to full extension when not mounted?
If they are- they may make the rig pull slightly until they break in.
If they are not gas charged- they should not make your rig pull to either side.
Check your air pressures.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
