Old 09-14-2016, 01:28 AM   #231
benagi's Avatar
Originally Posted by Total Loss View Post
Are they gas charged?
Do they push out to full extension when not mounted?
If they are- they may make the rig pull slightly until they break in.
If they are not gas charged- they should not make your rig pull to either side.
Check your air pressures.
Yes it does push out when not mounted. Thought that me be the problem. Surprised that little bit of pressure could make a 14000 lb vehicle pull.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 09-14-2016, 10:38 AM   #232
Total Loss's Avatar
Add some air to the left front tire.
Or let some out of the rt front until it eases up.
Try 2 or 3 lbs.
I don't know why they gas pressurize a steering stabilizer.
Doesn't seem right.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 09-15-2016, 01:38 AM   #233
benagi's Avatar
Try 2 or 3 lbs.
Doesn't seem right.
Good idea . Thx for the info.
1968 tent trailer
1985 Jamboree 23 ft
Old 09-16-2016, 12:31 PM   #234
Sagecoachdriver's Avatar
Had the front sway bar installed this morning, they striped both of the small rear bolts up front. Now I have to figure out who's going to fix it. I may have to remove the bumper myself and attach nuts.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 0trips 0 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-16-2016, 05:41 PM   #235
Thank you Benagi!
My local Ford dealer wouldn't touch the striped swaybar bolts and referred me to an Axle suspension shop and they wouldn't either and referred me to another shop and they said maybe. So I decided to see how difficult it would be to remove the front bumper as Benagi had the same issue. I easily removed the 4 bolts for the shroud cover and the 4 large bolts for the bumper. As you can see in the photos there is plenty of room to get a lock nut and socket in there. Ran to the hardware store and picked up some 10mm course locknuts. Installed the nuts on the 2 bolts and rechecked the steering stabilizer bolt that had striped a few weeks ago. Reinstalled the bumper and we are done!
Thanks so much for the tip Benagi!
ID:	120416   Click image for larger version
Old 09-16-2016, 07:47 PM   #236
Do you think they stripped the bolts as a result of using a impact wrench to tighten them as opposed to hand tightening them with a torque wrench? I'm going to be replacing both sway bars this weekend and noticed that the Hellwig front bar instructions do not have a torque table but the rear bar does.
newRVer is offline   Reply With Quote
Old 09-16-2016, 09:34 PM   #237
They used an impact wrench. I used a ratchet wrench with the lock nuts.
Not sure what to set a torque wrench to since the thread are striped.
Old 09-16-2016, 11:51 PM   #238
Helwigs 7718 and 7180? Let us know how it goes, especially the rear. Good luck!
Old 09-17-2016, 01:15 AM   #239
benagi's Avatar
Newrver, check out my post # 202 in this thread . Those rear bolts go thru a threaded frame with very few threads and strip very easy with just a 3/8 inch ratchet and not much pressure . Good luck with your install. Those Hellwig sway bars are well worth it.
1968 tent trailer
1985 Jamboree 23 ft
Old 09-17-2016, 08:37 AM   #240
Thanks! I will be paying attention to that.
