Old 09-17-2016, 09:59 AM   #241
Sagecoachdriver's Avatar
Originally Posted by benagi View Post
Newrver, check out my post # 202 in this thread . Those rear bolts go thru a threaded frame with very few threads and strip very easy with just a 3/8 inch ratchet and not much pressure . Good luck with your install. Those Hellwig sway bars are well worth it.
Ben, I thought it was just the fronts that had the striping issue and not the rear. How were you able to install the nuts atop the bolts? I haven't looked under the rear yet.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 0trips 0 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-17-2016, 10:17 AM   #242
Chief tinkerer
Gidyupgo's Avatar
2016 E450 Rear, with sway and trac bar mounts. Bolts that come with new bar are longer and grade 10.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 09-17-2016, 10:23 AM   #243
RedLdr1's Avatar
Who did your install, Three Way?
Wayne
2017 Sunseeker GTS 2800 QSF
TOAD: 2016 Ford Edge Titanium FWD
RedLdr1 is offline   Reply With Quote
Old 09-17-2016, 11:06 AM   #244
Chief tinkerer
Gidyupgo's Avatar
It ended up being a DIY. I tried to give three way the job but they said i needed to take it to a Ford dealer. It's not a bad job, but if I did it again I would have recruited a helper. This is pretty heavy stuff laying on your back in the street, heh heh. Do the sway and trac at the same time since they share some connection points.
Gary
Old 09-18-2016, 01:23 PM   #245
Well I did manage to install the Supersteer Trac Bar and Hellwig rear sway bar yesterday but ran out of time and the weather is not good today so the Hellwig front sway bar will have to wait for another day. A agree that this job is best done with two people. While the weight can be an issue (especially when your on your back) I was able to raise the sway bar up easy enough with a floor jack and bolt in the ends and D supports. I will say this, if for nothing else, having two people would have probably saved me some bruises on my hips as I was constantly rolling under the RV at 4 different points to get to assemblies in front or behind the axle.
I will have to wait till the next two weekends to determine how much better the new components are but I'm sure I'll see some improvement.
As for lessons learned. Make sure all bolts and nuts fit correctly and that you have the appropriate socket/wrench for each bolt. I got 95% done in a reasonable amount of time before I discovered that the two bolts used to mount the trac bar where a size that I did not have a socket or wrench for. Additionally, the two nuts for these bolts both had damaged threads at the top of the nut that I did not discover until after I had went out and purchased the additional tools. Consequently I burned up 4 hours of time running back and forth yesterday and it took me all of 10 minutes today to finish once I had the correct stuff.
ID:	120539   Click image for larger version
newRVer is offline   Reply With Quote
Old 09-18-2016, 09:09 PM   #246
Chief tinkerer
Gidyupgo's Avatar
Nice job New!
Gary
Old 09-18-2016, 09:36 PM   #247
Yes, nice job!
Old 09-19-2016, 08:38 AM   #248
Thanks Guys! Looking forward to getting the front sway bar ASAP but I will probably wait until after my next two trips are over just in case I run into some issues like stripped bolts and such.
Old 09-20-2016, 01:20 AM   #249
benagi's Avatar
Correct, just the front has the stripping issue. The rear is completely a different mounting and comes with all new hardware and bolts. If installing yourself, try to get a second person. We also used a floor jack to help with lifting that very heavy rear sway bar.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 09-20-2016, 01:24 AM   #250
benagi's Avatar
Bilstein steering stabilizer
Newrver, nice job. Question, what made you go with the supersteer Trac bar? Thinking about adding one to our unit.
1968 tent trailer
1985 Jamboree 23 ft
