Old 09-20-2016, 12:23 PM   #251
Originally Posted by benagi View Post
Newrver, nice job. Question, what made you go with the supersteer Trac bar? Thinking about adding one to our unit.
Mostly just cost as I could not find any information from a performance/installation perspective that would indicate SuperSteer was better than Blue OX or visa-versa.
newRVer is offline   Reply With Quote
Old 09-20-2016, 12:34 PM   #252
DW's Retirement Plan
DaGrinch's Avatar
Originally Posted by newRVer View Post
Well I did manage to install the Supersteer Trac Bar and Hellwig rear sway bar yesterday but ran out of time and the weather is not good today so the Hellwig front sway bar will have to wait for another day. A agree that this job is best done with two people. While the weight can be an issue (especially when your on your back) I was able to raise the sway bar up easy enough with a floor jack and bolt in the ends and D supports. I will say this, if for nothing else, having two people would have probably saved me some bruises on my hips as I was constantly rolling under the RV at 4 different points to get to assemblies in front or behind the axle.
I will have to wait till the next two weekends to determine how much better the new components are but I'm sure I'll see some improvement.
As for lessons learned. Make sure all bolts and nuts fit correctly and that you have the appropriate socket/wrench for each bolt. I got 95% done in a reasonable amount of time before I discovered that the two bolts used to mount the trac bar where a size that I did not have a socket or wrench for. Additionally, the two nuts for these bolts both had damaged threads at the top of the nut that I did not discover until after I had went out and purchased the additional tools. Consequently I burned up 4 hours of time running back and forth yesterday and it took me all of 10 minutes today to finish once I had the correct stuff.
As the others have said..... Nice Job!
I know what you and Gidyupgo mean about having some help. Sure would have been nice!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life...
DaGrinch is offline   Reply With Quote
Old 09-20-2016, 02:05 PM   #253
Chief tinkerer
Gidyupgo's Avatar
New, likes Blue, 'cause it rhymes, hehe
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 10-03-2016, 01:05 PM   #254
Well I must say that after putting 700+ miles on the RV, post rear sway & trac bar upgrades, the handling of the vehicle is much improved. This included 260 miles on the PA turnpike with lots of trucks passing me on the left and now it's hardly a noticeable event. I'm sure that when I replace the front sway bar in a few weeks time it will even be better although I may not be making any more trips this year to really test it out.
Old 10-03-2016, 07:49 PM   #255
Chief tinkerer
Gidyupgo's Avatar
NewRV, that's great! Glad you had a good experience.
Gary
Old 10-23-2016, 06:39 PM   #256
So the weather was good today and I had no plans so I thought I thought I could spare a few hours and try and get the front sway bar on. The back bolts on the d-clamp came off easy enough but the front bolts were secured with some loctite blue on them which made it slow going to get them off since I do not have an impact wrench. Once off I can see why some people had issues with the back bolts stripping. The are much smaller (see photo) and do not have a nut on the inside of the frame. I suspect that people might be making the mistake of tightening these bolts last after tightening the fronts since the directions give no particular order. If you do it this way the bolts while surely pull through. So based on my experience with the back sway bar, this time I did check all the bolts, cleaned off the loctite and tried putting them back in before mounting the new sway bar. And just like the rear sway bar, I ran into another issue. One of the larger d-clamp front bolts either got stripped during the factory install or they over did it with the loctite and somehow that damaged the threads as I was slowly backing them out. Either way I had to take off the bumper to really see what was going on. (see picture).
At this point I need to figure out what is the best way of correcting this. Do I get a bit and try re-threading the hole? Or do I just drill it out and place another nut on the existing one inside the frame?
Suggestions?
ID:	123706   Click image for larger version
ID:	123707   Click image for larger version
Old 10-23-2016, 11:43 PM   #257
Sagecoachdriver's Avatar
Suggestions?
Been there, done that. I found the easiest way was to reinsert the stripped bolt, place a washer and lock nut on the inside of the frame. Then I placed a wrench on the nut and tightened the bolt on the outside. Amazing that my bumper only had four bolts holding it on. Took less than 5 minutes to remove. You could insert the bolt from the inside and have the nut on the outside, but it may be difficult inserting the bolt.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 0trips 0 nights
Sagecoachdriver is online now   Reply With Quote
Old 10-24-2016, 01:59 AM   #258
benagi's Avatar
Did the same thing as Sage. Just used the original bolt and backed with a nut and lock washer. Works great and shouldn't have to worry about again .
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 10-24-2016, 07:41 AM   #259
Sage,
In my case, I am having the issue with the larger bolt and the bolt itself is not stripped but the large nut that is welded to the inside of the frame is.
Old 10-24-2016, 10:53 AM   #260
Sage,
What's the issue, diffcult to get going and ever harder too tighten?
