Old 11-06-2015, 10:24 AM   #61
papap's Avatar
I decided to go ahead an ordered the roadmaster. 235$ at camping world
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 11-06-2015, 10:34 AM   #62
Boso's Avatar
At least you can adjust to get tru center if it pulls either way and that option is not available on the bilstein gas damper
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 11-06-2015, 04:58 PM   #63
Hey Boso ,I have been reading about others complaining that the gas pressurized damper causes steering turning on its own, have you seen any reports on how just a heavier ( non-gas) duty damper ( anything is better than the OEM one) affects the steering wander?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 11-06-2015, 05:15 PM   #64
Boso's Avatar
I went with the Roadmaster reflex steering just because it was on sale and the reviews were good I didnt want to take a chance on the bilstein and have that pulling problem just the safest and easiest way to go for me but there are a lot of options as far as different manufactures still hoping airbags are fixed when I get RV back
Old 11-08-2015, 02:15 PM   #65
vwexpert's Avatar
I just replaced my stock damper with the a new Bilstein. The stock damper was already shot - it had 2 - 3 inches of none dampened movement.
1971 20ft fireball (too small)
1987 27ft Tioga (bad brakes / tires)
1998 36ft Discovery (rattles / air leaks)
2005 37ft Monaco Knight (lemon Lawed)
2008 40ft Monaco Diplomat (too big)
2016 Forester 3011 (ordered June 8th - Born Aug 6) IT'S HERE
vwexpert is offline   Reply With Quote
Old 11-08-2015, 02:28 PM   #66
Boso's Avatar
How many miles did the damper have on it I didn't even check mine could see the difference in size that Sage had posted so I new the stock one was piece of junk
Old 11-08-2015, 06:27 PM   #67
Sagecoachdriver's Avatar
VWexpert I just replaced my stock damper with the a new Bilstein. The stock damper was already shot - it had 2 - 3 inches of none dampened movement.
That's what the alignment shop meant when they said I had a flat spot. I did notice a lot of looseness periodically for and instant. No more!
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 11-08-2015, 08:17 PM   #68
benagi's Avatar
Wow, the stock damper already shot. Your unit is 2 months newer than ours. Looks like I will be ordering the Bilstein also. Have you read about some of the problems the Bilsteins have had in this thread? Should we worry? Looks like Sage is having good luck with his.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 11-08-2015, 09:08 PM   #69
vwexpert's Avatar
We have 3,000 miles on it. Wasn't able to test drive yet as it started to rain and I just waxed it. Heading over to Monterey this weekend - we'll see if the alignment and damper help. Looks like I might need to take the coach back to the alignment shop to have the FR alignment specs used.
Old 11-08-2015, 09:14 PM   #70
Boso's Avatar
Took me 3 times at alignment shop with the specs to get it right and still bothered by wind which I hope the Roadmaster will solve
Old 11-08-2015, 09:58 PM   #71
Interesting encounter
Today, the DW and I went to CW for a trike on sale. We noticed a very new (2015/2015) Forester 3011 in the parking lot and as the DW test rode the trike, I caught the owner just as he was leaving. I mentioned I had a 2701 and asked how his drove and if it wandered. He replied that it did and said it was from the weak OEM shocks and I think stabilizer too. He said the shocks were the same as a regular van and too weak for a MH. I said that I was eventually changing mine to Bilsteins and the said he was installing Ranchos. As far as the stabilizer, he doesn't like the lack or road feel one gets with the Roadmaster and again, he's going with Rancho.
I did tell him about the forum and hoped that he would look us up. He's had his 3 weeks and I told him about updating the maps.
So shocks designed for the heavier load of a motorhome is another option.
Old 11-08-2015, 10:25 PM   #72
Boso's Avatar
Sage you did say he had his for all of 3weeks
Old 11-08-2015, 11:14 PM   #73
Yes, I believe that's what he said. His CA license number was close to mine and mine has been 10 weeks.
Old 11-08-2015, 11:24 PM   #74
vwexpert's Avatar
I have a friend that has a 2015 sunseeker 3010 that he installed bilstein shocks on. He said he regretted doing that...he can feel every bump with them. He does not know if they were HD or comfort ride shocks.
Old 11-09-2015, 12:31 AM   #75
VWexpert, I had the comforts on my Winnebago and had a noticeable increase in handling. Plus it eliminated porpoising that I had. My Winnebago was only 22 feet and comfort was recommended. At 28 feet Forester , I'm at the upper limit for the comfort.
I'll bet your friend has the Heavy duty as I think 30 feet and above are recommended.
Old 11-09-2015, 11:25 AM   #76
vwexpert's Avatar
I also believe he has HD's on his coach. I am ordering a set of comforts today. I may order comforts for the front and HD for the rear. We do that on Vanagons using KYB's and they handle nice with a smooth ride. I installed a set of HD (high pressure) KYB's on the front of a Rabbit pick up - customer hated the ride...I had to change them to the Low pressure shocks.
Old 11-09-2015, 11:37 AM   #77
vwexpert's Avatar
He is a bilstein quote "The Bilstein Comfort uses all of the Bilstein Heavy Duty's monotube technology and high end ride control, but is designed more for comfort than performance. Comfort shocks will provide you with the same reliability and durability as the Heavy Duty, but with a softer ride."
Old 11-09-2015, 12:00 PM   #78
vwexpert's Avatar
I talked myself into the bilsteins - comfort front and HD rear.
Old 11-09-2015, 12:18 PM   #79
Boso's Avatar
I just can't see where they would make any difference in the rear with having air bags and I don't think you will see a difference in the front but I could be wrong
Old 11-09-2015, 12:47 PM   #80
vwexpert's Avatar
My thought is - this rear suspension with the air bags is a lot stiffer than a stock e450, thus it needs more dampening to control the ride and after seeing how poor quality the damper was...ANY upgraded shock should improve the handling.
