Old 06-12-2016, 06:51 PM   #1
imavol's Avatar
Black water flush nozzle clogged
I have a 2014 3011 and have a clogged black water flush nozzle. I have eliminated the B&B back flow preventer as the problem by removing and replacing with an elbow and used an external back flow preventer. I have also tried filling the tank with fresh water and soaking for several days. I have also tried CLR in the fill tube before the nozzle with no luck. I am trying to find where the nozzle is located so that I can remove and manually clean. Can anyone help me as to how to access the nozzle for removal.?
imavol is offline   Reply With Quote
Old 06-15-2016, 07:13 AM   #2
2012 Sunseeker 2650CDS
Ill send you a picture later. It's surprisingly easy to fix - just did mine. Philips screwdriver, some silicone, 15 minutes. It has three screws. Undo screws, pull flush out of black tank, spin it off the flush hose, spin new one on, apply silicone liberally, push back in tank, screw it back in, done. I filled the tank full and drove around for awhile to make sure it wouldn't leak and then dumped testing the flush valve at that time. No problem. Wear gloves so you don't get poop on your hands.
Sunseeker 2650
mrwiensie is offline   Reply With Quote
Old 06-16-2016, 08:38 PM   #3
Forester Fred's Avatar
Location: On the road between New Hampshire and Florida
Take a look at this thread: Black tank flush issues - need input
2015 Forester 2301 - Chevy
Skip & Deb - Bridgewater, NH & Delray Beach, FL
Forester Fred is offline   Reply With Quote
black, black water, water
