Old 10-12-2015, 11:52 PM   #1
Creativepart's Avatar
Black water tank flush not working
When I first got my 3051S in June the BW Flush worked fine but right away it stopped working. Sounds like a bad check valve to me. Water pressure builds up in the hose and only a trickle comes out of the sewer house. Plus it makes a loud whining sound in the wall.
Anyone else seeing this issue?
2017 Winnebago Adventurer 37F
TOAD: 2016 Lincoln MKX
Creativepart is offline   Reply With Quote
Old 10-13-2015, 12:20 AM   #2
Sagecoachdriver's Avatar
CReativepart, I have seen many posts on this topic. Just do a search. Many replace the valve with a metal one from Lowes or Home Depot. We are lucky, some had theirs installed backwards. I have only used mine twice and no problems. Some say they can get clogged too.
I wonder if using very warm water would make a difference and clean it out if clogged?
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
Sagecoachdriver is offline   Reply With Quote
Old 10-13-2015, 08:13 AM   #3
I really doubt it's a clog. Our RV had only been used twice for short weekend trips right after picking it up that it stopped working.
I found an access hole with a screw off plastic cover in the closet in the bedroom that backs up to behind the shower. The check valve is in there. But it's just about impossible to get in there to work.
I'm going to call the local FR dealer and make an appointment to get this fixed under warranty. We'll see just how good a dealer this local guy is. I purchased mine from a dealer 4 hours away. This local dealer had no new 3051S's in stock and tried to sell me a used 2014 for $5,000 more than the new one cost from the dealer 4-hours down the road.
He's a big Motorhome dealer though with a shop here near San Antonio and an even bigger well known dealership up in the RV capital of Texas... Alvarado, TX.
Old 10-14-2015, 02:17 PM   #4
Frank & Eve's Avatar
Have a 2012 3011...black flush has never worked. Forgot to mention it the two times we've had it in for warranty work. Do any of you know where this check valve's location in this unit?
Sent from my MB886 using Tapatalk
Frank & Eve is offline   Reply With Quote
Old 10-14-2015, 02:45 PM   #5
Well, I just called the service dept and... NO PROBLEM! That was a pleasant surprise. Outside of them being 1-month out on service appointments they said no problem doing warranty work.
So, it goes in on Nov 17th and they said they'd get it done in 4 or 5 days.
My local dealer is Ancira RV in Boerne, Texas.
I'm so happy to hear them not give me any problem about bringing in warranty work even though I purchased at a different dealer. That's a relief.
Old 10-15-2015, 12:29 PM   #6
Lexi2007's Avatar
I also have an appointment at Ancira RV for 2 warranty items plus a lot if other non warranty concerns. Hope they get it all handled. Has anyone tried the blackwater tank wand lije they have at CW? Our rig didn't come equipped and already the indicator shows 2/3 full even though it's completely empty.
Lexi2007 is offline   Reply With Quote
Old 10-15-2015, 01:00 PM   #7
A32Deuce's Avatar
I have a SunSeeker and they did mine at Goshen. Removed drawer in bathroom and valve was located there. Took longer to remove drawer than to fix. I watched.
A32Deuce is offline   Reply With Quote
Old 10-15-2015, 03:46 PM   #8
2016 Avenger 26BH
My "self installed" tank flush whines when it is working. I can also hear the water hitting the tank sides as it spins. last sunday I was rinsing the black tank and only had a trickle coming out. it took a while, but eventually a large ball of "wet wipes" washed out then the flow returned to normal. You may a obstruction in the tank as well. I know who put the wet wipes in there and that wont happen again. good thing she's my kid......
Cleon is offline   Reply With Quote
Old 11-29-2015, 10:16 PM   #9
Lexi2007...Yes we have the wand that you connect to a water hose and stick the wand down the toilet. Works great.
Old 12-01-2015, 01:26 AM   #10
While I had my 3051s at the dealer for service I had them check this problem out. Of course, the black water flush system worked normally.
We're going camping on Wednesday - any bets on whether it works for me or not??
black, black water, tank, water, water tank
