Old 08-02-2019, 07:16 AM   #1
Blocked vents on refrigerator access panel
Iíve taken delivery of a new Sunseeker and Iíve been going through the unit thoroughly to inspect every aspect of it. I uncovered one particular flaw that I thought was worth passing on.
Our unit has the full body paint option, and overall the paint job was done very well. I appreciate that the paint shop masked off the vent holes in the lower outer refrigerator access cover, so as not to have paint overspray inside the refrigerator guts. However, no one apparently took the time to remove the masking tape before delivery.
I, and probably the dealer, tested the refrigerator and it got cold, so the taped up holes could be easily overlooked. Obviously, having all the vent holes plugged is not best for operation over the long term.
So, if you took delivery of a full body paint Sunseeker, you may want to check that the refrigerator lower vents are not covered with tape on the backside.
BehindBars is offline   Reply With Quote
lock, refrigerator, sunseeker, vent
